SetfieldsDict in the multiphaseInterFoam
Old   September 18, 2013, 02:54
Post SetfieldsDict in the multiphaseInterFoam
salame ama
salame is on a distinguished road
Hi, Formers:
It is a problem confused me a lot of days. i want to use the multiphaseInterFoam to stimulate different fluid inject in a cavity sequentially.
If one fluid injection is finished, how can the setfieldsDict be set for the next one?
If the setfieldDict not changed, i have tried this way, the calculation of the next fluid would begin from the end of previous fluid. But the result is not OK.
So, can you give me any advise?
Best regards!
salame is offline   Reply With Quote
Old   September 20, 2013, 16:50
Matthew Denno
mgdenno is on a distinguished road
If I understand what you are trying to do, I would say that maybe you need to change the fluid entering the system using a different boundary condition and not setFields. Maybe something like the uniformFixedValue with a time varying uniformValue shown here:
http://www.openfoam.org/version2.1.0...conditions.php
I have not tried this but it is where I would start.
mgdenno is offline   Reply With Quote
Old   September 23, 2013, 03:05
Unhappy
salame ama
thank u for your reply! Matthew.
i have seen the webpage you recommended. To my issue, the change of u is not
enough, the fluid also be changed. like:First, water; second, oil.
Old   September 23, 2013, 12:19
Matthew Denno
I would think that you could use this BC to change the boundary conditions in your alphaair and alphawater files to change the fluid coming into the domain.
in alphawater:
inlet
        type uniformFixedValue;
        uniformValue     table
            (  0   1.0)
            (100  0.0)
in alphaair:
inlet
        uniformValue     table
            (  0   0.0)
            (100  1.0)
to switch from water to air at t=100.
Like I said, I have never done this but it is where I would start.
Let me know if it works.
Old   October 22, 2013, 10:17
Post
salame ama
sorry to reply you so later, Matthew.
your patient reply is appreciated, thank you! i have done the steps like you say. in my case, there are 3 fluids, two Non-newtonian and one Newtonian. properties file:
.phases
               oil {
                           transportModel  powerLaw;
                            nu              nu [0 2 -1 0 0 0 0] 1;
                           rho             rho [1 -3 0 0 0 0 0] 748.5;
                              powerLawCoeffs
                k             k [0 2 -1 0 0 0 0] 9.065;
                n             n [0 0 0 0 0 0 0] 0.35;
                nuMin         nuMin [0 2 -1 0 0 0 0] 0.001336;
                nuMax         nuMax [0 2 -1 0 0 0 0] 8.5504342;
           mercury {
                        rho             rho [1 -3 0 0 0 0 0] 850.5;
                              powerLawCoeffs
                k             k [0 2 -1 0 0 0 0] 7.065;
                n             n [0 0 0 0 0 0 0] 0.25;
                nuMin         nuMin [0 2 -1 0 0 0 0] 0.01336;
                nuMax         nuMax [0 2 -1 0 0 0 0] 7.4504342;
               air { transportModel Newtonian ; nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-03 ; rho rho [ 1 -3 0 0 0 0 0 ] 1 ; }
refPhase        air;
And i set the alphaoil and alphamercy like this: oil
 inlet
        uniformValue    table
(0 1)
(0.2 0)
. mer
inlet
        uniformValue    table
         (0 0)
         (0.2 1)
the V file:
inlet
        uniformValue    table
              (0 (1 0 0))
              (0.2 (0.5 0 0))
. the 3 files are used the new boundrys like you say. But, i felt uncertain about the result (0.2s) :截图00.jpg, the left is the inlet , blue is the air and just the 0.2 second result, i am puzzled about this picture like water-jetting. Does the multiphaseInterFoam solver just for newtonian fluid? By the way, do you know how is the new BC setting as we mentioned in the version 1.6-ext?
Best regards!
salame
multiphaseInterFoam: timestep error by simulating a co-extrusion nozzle Quatschinsky OpenFOAM Running, Solving & CFD 7 March 27, 2014 05:08
SetFieldsDict: Non uniform density physics1 OpenFOAM Running, Solving & CFD 1 May 8, 2013 16:35
convergence issue with multiphaseInterFoam sachinlb OpenFOAM Running, Solving & CFD 2 October 12, 2012 11:45
alphaEqn in multiphaseInterFOAM 2.1 sina.s OpenFOAM Programming & Development 2 March 9, 2012 04:30
VOF fraction in multiphaseInterFoam mahaputra OpenFOAM Running, Solving & CFD 1 August 27, 2009 08:15
