pisoFoam error at t= 0.44 seconds: how to debug? |
September 30, 2013, 13:23 |
Reno
pisoFoam runs fine until t=0.448 sec.
After that it diverges and crashes with following error: Code:
Time = 0.44865 Courant Number mean: 0.0346229 max: 2.25125 GAMG: Solving for Ux, Initial residual = 0.0021901, Final residual = 8.33515e-10, No Iterations 7 GAMG: Solving for Uy, Initial residual = 0.00282035, Final residual = 6.47015e-10, No Iterations 10 GAMG: Solving for Uz, Initial residual = 0.00343254, Final residual = 5.81644e-10, No Iterations 8 GAMG: Solving for p, Initial residual = 0.00599169, Final residual = 9.90127e-10, No Iterations 23 GAMG: Solving for p, Initial residual = 0.00258563, Final residual = 9.61956e-10, No Iterations 19 GAMG: Solving for p, Initial residual = 0.000292086, Final residual = 6.42802e-10, No Iterations 14 time step continuity errors : sum local = 1.74226e-13, global = 4.33102e-14, cumulative = 1.06683e-11 GAMG: Solving for p, Initial residual = 0.000725654, Final residual = 8.53172e-10, No Iterations 19 GAMG: Solving for p, Initial residual = 0.000331136, Final residual = 9.20399e-10, No Iterations 14 GAMG: Solving for p, Initial residual = 4.45138e-05, Final residual = 7.34497e-10, No Iterations 11 time step continuity errors : sum local = 1.99139e-13, global = 1.92587e-14, cumulative = 1.06875e-11 GAMG: Solving for p, Initial residual = 0.000184586, Final residual = 8.57881e-10, No Iterations 13 GAMG: Solving for p, Initial residual = 4.75742e-05, Final residual = 9.46137e-10, No Iterations 11 GAMG: Solving for p, Initial residual = 6.96925e-06, Final residual = 5.26146e-10, No Iterations 9 time step continuity errors : sum local = 1.42648e-13, global = -7.47356e-15, cumulative = 1.06801e-11 GAMG: Solving for p, Initial residual = 6.69644e-05, Final residual = 8.2169e-10, No Iterations 13 GAMG: Solving for p, Initial residual = 1.7527e-05, Final residual = 6.28005e-10, No Iterations 10 GAMG: Solving for p, Initial residual = 2.47075e-06, Final residual = 9.4613e-10, No Iterations 8 time step continuity errors : sum local = 2.56509e-13, global = -1.55041e-14, cumulative = 1.06645e-11 ExecutionTime = 16316.8 s ClockTime = 16319 s Time = 0.4487 Courant Number mean: 0.0346816 max: 2.40047 GAMG: Solving for Ux, Initial residual = 0.00230011, Final residual = 8.51017e-10, No Iterations 50 GAMG: Solving for Uy, Initial residual = 0.00294039, Final residual = 9.44201e-10, No Iterations 44 GAMG: Solving for Uz, Initial residual = 0.00345345, Final residual = 9.30589e-10, No Iterations 37 GAMG: Solving for p, Initial residual = 0.00685504, Final residual = 9.21598e-10, No Iterations 24 GAMG: Solving for p, Initial residual = 0.00292084, Final residual = 8.05039e-10, No Iterations 19 GAMG: Solving for p, Initial residual = 0.000342391, Final residual = 7.3001e-10, No Iterations 15 time step continuity errors : sum local = 1.98285e-13, global = -4.52974e-14, cumulative = 1.06193e-11 GAMG: Solving for p, Initial residual = 0.000871317, Final residual = 7.51135e-10, No Iterations 20 GAMG: Solving for p, Initial residual = 0.000449259, Final residual = 8.33107e-10, No Iterations 14 GAMG: Solving for p, Initial residual = 5.69199e-05, Final residual = 8.8222e-10, No Iterations 12 time step continuity errors : sum local = 2.39695e-13, global = 7.09848e-14, cumulative = 1.06902e-11 GAMG: Solving for p, Initial residual = 0.000201523, Final residual = 9.68937e-10, No Iterations 15 GAMG: Solving for p, Initial residual = 5.71848e-05, Final residual = 6.92029e-10, No Iterations 12 GAMG: Solving for p, Initial residual = 8.31359e-06, Final residual = 4.91838e-10, No Iterations 10 time step continuity errors : sum local = 1.33629e-13, global = 6.47104e-15, cumulative = 1.06967e-11 GAMG: Solving for p, Initial residual = 8.53963e-05, Final residual = 5.8034e-10, No Iterations 14 GAMG: Solving for p, Initial residual = 2.4869e-05, Final residual = 9.15113e-10, No Iterations 10 GAMG: Solving for p, Initial residual = 2.8086e-06, Final residual = 5.25217e-10, No Iterations 9 time step continuity errors : sum local = 1.42697e-13, global = -6.84406e-15, cumulative = 1.06899e-11 ExecutionTime = 16320.8 s ClockTime = 16323 s Time = 0.44875 Courant Number mean: 0.0347408 max: 2.57326 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam221/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #7 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/pisoFoam" #8 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/pisoFoam" #9 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/pisoFoam" #10 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/pisoFoam" #11 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #12 in "/opt/openfoam221/platforms/linuxGccDPOpt/bin/pisoFoam" pisoFoamcheckMesh HTML Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 14939 faces: 141770 internal faces: 128226 cells: 67499 faces per cell: 4 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 67499 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology patch0 1088 591 ok (non-closed singly connected) patch1 1072 585 ok (non-closed singly connected) patch2 11384 5786 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.003668 -0.004318 -0.039265) (0.003663 0.004173 0.039411) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (3.58681e-18 -5.3928e-17 4.29723e-17) OK. Max cell openness = 1.47362e-16 OK. Max aspect ratio = 8.23769 OK. Minimum face area = 1.8095e-10. Maximum face area = 2.23531e-06. Face area magnitudes OK. Min volume = 1.335e-15. Max volume = 7.98174e-10. Total volume = 1.84215e-06. Cell volumes OK. Mesh non-orthogonality Max: 76.1503 average: 15.438 *Number of severely non-orthogonal faces: 3. Non-orthogonality check OK. <<Writing 3 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 0.862973 OK. Coupled point location match (average 0) OK. Mesh OK. End I am trying to find out how to get rid of above errors, I can run another case successfully with my case settings, as well this case until 0.44 sec. I know my mesh is not that great. I am wondering by keeping the above mesh, how I can run the simulation successfully. Alternatively, is anyway I can debug? Best jay Last edited by jr33; October 2, 2013 at 00:51. |
October 2, 2013, 00:59 |
Reno
Hi Foamers, after searching many threads, I realized that improving mesh is the best solution for my problem. The new minimum volume in the mesh is approximately close to 1E-15. still not better, Now, I can run my simulation for 0.89 seconds. I wanted to do it for 1 sec. In conclusion, I guess the mesh quality is the key to resolve above errors.
create the file *.foam | phongstar | OpenFOAM | 12 | October 14, 2018 18:06 |
Eclipse - case debug error | Bufacchi | OpenFOAM | 1 | February 7, 2012 15:15 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
