why pisoFoam take such a long time to converge? |
#1 | ||
izna O'connor
Rep Power: 12 ![]() |
Hello
I have a PC with 4GB RAM 2 processors.. Ihave run a simulation with pisoFOam and today is 48 hours since i last start.. and still convergence not acheived..!! Can anyone give me a better way to acheive convergence easier with pisoFoam? I am attaching my fv solution just so that you may know what i did.. Quote:
Niels Gjoel Jacobsen
Rep Power: 37 ![]() ![]() |
Good evening,
pisoFoam is intended for transient simulations, which does not necessarily have a steady state solution. Also, to my knowledge, the pisoFoam does not check for the residualControls, which you have in your fvSolution file. For steady state simulations you would probable want to look into e.g. simpleFoam. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
izna O'connor
hi..
simpleFoam is not working at all for the case that running... hence am running with pisoFoam, and its working with pisoFoam.. but taking such a long time!!!! |
Philipp
Rep Power: 26 ![]() |
Is this a transient simulation or steady state?
The skeleton ran out of shampoo in the shower. |
#5 | |
izna O'connor
steady state..
Philipp
You are using the wrong solver. You solve for a transient simulation, time-scheme is Euler and your time-step is 0.5ms.
This is not steady-state. 1) Use simpleFoam! Why do you say "simpleFoam is not working at all for the case that running"? SimpleFoam is a steady state solver. 2) Use GAMG solver for pressure. 3) "Linear" discretization doesn't converge very well. You can try some more dissipative scheme (upwind, linearUpwind,...).
izna O'connor
i already did all that with simpleFoam.. But after 300 timestep my solution crash.. and when i check in paraView, i see my domain as a blueeee one.. ie no velocity has enter... hence why i was soo desperate...
Philipp
Then you did it wrong
![]() Post your simple solver settings and then the residuals.
#9 |
Rep Power: 19 ![]() |
You have specified Euler to be used as time integrator, hence your simulation is transient. Period.
Anyways, as others have mentioned, pisoFoam will not obey the residual limits you have specified. It will run until it reaches endTime, no matter how steady the simulation are. If you want a steady-state result then simpleFoam is the one and only solver to use. However, some cases will not converge to a steady state, simply because they are transient by nature. For such cases steady solutions are difficult to obtain, and if you can get one, you are almost certain that it is non-physical. If your case involves geometries and flow conditions leading to for example vortex shedding, that forces you to use a transient solver if you want physical results. That is just how nature works. (BTW: You can probably get almost any case to converge in steady state by using 1st order upwind schemes (=extreme diffusivity), heavy relaxation and other "stabilizing tricks", but will give you unusable results, so in practice it is not possible...) |
#10 | ||
izna O'connor
simple Solver settings..:
#11 | |
izna O'connor
Can you please give me an example where the upwind scheme is 1strorder? me i am simulating 10 shapes in a domain..that is all and its in 2D.. so i guess it should converge normally right?? for 12 days i am with this problem..and with pisoFoam its nto crashing..but today is my 3rd day where simulation is running.. so am a bit desperate now... ![]() |
#12 |
I guess that probably is just the "upwind" scheme, but I have never used it, as it produces just crap.
Why are you using zero non-orthogonal correctors? Have you tried increasing this value? Why are you only using relaxation for the pressure and not the velocities when running simpleFoam? I would lie to emphasize a few things:
#13 | |
izna O'connor
my mesh is fine..
![]() From the errors it say.. Quote:
#14 |
Philipp
Can you post the residual plot?
1) What happens, if you set "relTol" for the pressure to 1.0e-3? Do the residuals change? 2) What happens, if you use some gradient limiter? Such as Code:
gradSchemes { default faceLimited edgeCellsLeastSquares 1; } Code:
... div(phi,k) bounded Gauss upwind;
#15 |
izna O'connor
am sorry for late reply.. but for each of the above mentioned points. My solution crash..
Now am worried.... ![]() |
#16 |
Philipp
Can you send the whole log-output? So we can try to find the spot...
#17 |
izna O'connor
hi..afte changing the fv solution and fv schemes.. I obtain a good simulation which i checked..
.. when arriving at 1760 iteration the solution crashed.. and when i checked in paraView.. I obtain a blue domain.. Why such a nice simulation suddenly crash ? |
#18 |
Philipp
You have to share all relevant data, otherwise no one will be able to help you.
1) log output 2) boundary condition files 3) screenshot of your domain with grid. Additionally: It seems you use the k-epsilon model. In your fvSolution file you set relaxation factors, but not for k-epsilon but for k-omega. This could be the reason.
#19 |
Danesh S
Hi all,
I have a question which is close to the topic. Niels said above, that pisoFoam does not check for residualControls. Does that mean, that when running a transient turbulent simulation on pisoFoam, the residual output does not indicate the state of convergence of my simulation? I have the problem at the moment with my simulation. The residual is not dropping anymore, so I have no convergence. (It is LES of Taylor Couette Flow). I use backward time scheme and gauß upwind for U divscheme. My schemes should be fine. After reading this thread I am just worrying, that the solver is not able to produce what I want. Can anybody comment on this? Thx! Danesh |
#20 |
You are correct. pisoFoam does not obey the residual controls. This is because the solution is time-accurate, i.e. every step is a valid solution of the transient problem. Hence, each step is solved until the specified tolerance level in fvSolution, and not further. Then the time is advances and a new solution is found. The value of the time step is hence important, as the PISO-algorithm cannot handle large time steps.
Remember my earlier comments on fluid flows that generally are transient by nature. I do not feel that you have clearly out-ruled this issue yet. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
PisoFoam case terminating | Solo Sails | OpenFOAM Running, Solving & CFD | 3 | November 29, 2011 07:04 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
