theta outer for cone injection
Old   November 14, 2013, 11:08
Default theta outer for cone injection
Chrisi1984 is on a distinguished road
Hello all,
I would like to know which angle should I type for "theta outer" for a cone injection?
Is theta outer the whole cone angle or just the half cone angle (That means the angle between the cone central axis and the cone border)?
Thanks in advance!
Kind regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   November 14, 2013, 12:32
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
It depends on the version of OpenFOAM you are using. For anything in 2.0.x or earlier, its the full angle assuming you are using the hollowCone/coneInjector, whereas for 2.1.x and later its the half cone angle when you are using coneNozzleInjector
mturcios777 is offline   Reply With Quote
injection problem Mark New FLUENT 0 August 4, 2013 01:30
jou file command for the injection! asal FLUENT 0 June 4, 2013 04:15
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
using injection file and parallel process Cindy Jones FLUENT 0 January 23, 2003 12:40
