ERROR : Floating point exception (core dumped) |
Rep Power: 12 ![]() |
Hi ,
I am simulating a steady state turbulent flow inside a valve using simpleFOAM. The valve has 1 inlet and 4 outlets Boundary Conditions INLET OUTLET Velocity 0.27 m/s zeroGradient pressure freestreamPressure fixedvalue 0 and all other boundaries like spring, spring support and valve body as no-slip condition and zero gradient pressure condition. I am getting an error which has been attached with this post. Please look in to the problem and let me know how to avoid this error. |
Rep Power: 15 ![]() |
Your continuity error is basically 1e19! Your simulation has diverged. Check your boundary conditions. Or perhaps post the case here. Regards, Antimony |
I just switched off the turbulence model and run the case( with same boundary conditions) . Its running fine with continuity error decreasing as we can see in the attachment . But why its not running when we switch on the turbulence model ? Any suggestions ? |
May I ask why is the p equation being solved three times within the same time step? Can you post your case without the mesh here? Regards, Antimony |
[FoamFile
{ version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 100; deltaT 10e-6; writeControl timeStep; writeInterval 10000; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 8; runTimeModifiable true;] [FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,R) bounded Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************** *********************** //] [FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.01; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } k { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } R { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } nuTilda { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; pRefCell 101; pRefCell 58; pRefCell 767; pRefCell 527; pRefValue 0; residualControl { p 1e-2; U 1e-3; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; } equations { U 0.5; k 0.5; epsilon 0.5; R 0.5; nuTilda 0.5; } } // ************************************************** *********************** //] |
pimpleDyMFoam constantly giving floating point exception and solution divergence | fedvasu | OpenFOAM Running, Solving & CFD | 0 | November 28, 2013 00:53 |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 14:11 |
Finished simulation doesn't start: floating point exception [Divide by zero] | MaxCFD | STAR-CCM+ | 3 | June 26, 2011 10:31 |
Flouting point exception twoPhaseEulerFoam - I set delta t | cristina87 | OpenFOAM | 1 | May 26, 2011 15:35 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
