conjugate heate transfer: thermophysical properties
Old   December 8, 2013, 00:43
Default conjugate heate transfer: thermophysical properties
Sergey
skuznet is on a distinguished road
Hello FOAMers!
I'm trying to simulate conjugate heat transfer in a simple heat exchanger using chtMultiRegionSimpleFoam. I have a water flowing between heated metallic plates. I was able to set up a case based on examples multiRegionHeater and planeWall2D. In these examples air with perfectGas equation of state is used. When I run it with air, the results look ok, at least qualitatively.
However, I would like to use water instead of air, and perfectGas equation of state can't be used.
I tried to use file thermophysicalProperties from the
/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater/constant/bottomWater/thermophysicalProperties (which is for transient solver)
instead of the file with air properties, I also changed density limits in the system/fluidDomain/fvSolution.SIMPLE. With this changes I was able to run my case, however the results are not correct. The fluid domain doesn't get heated. The temperature increases only on the boundaries of the fluid domain, inside fluid domain temperature does not change. There is something wrong with my definition of fluid, looks like there is no heat conduction inside fluid.
I wonder if anyone can explain me what do I do if I want to use water instead of air?
Can I use water properties from
/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater/constant/bottomWater/thermophysicalProperties (which is for transient solver)?
If yes, what else I should change in my case?
It would be great if someone can give me a working example of using chtMultiRegionSimpleFoam with water or any other liquid, not gas.
Thank you!
skuznet is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 11:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
