Mass conservation problem with compressibleInterDyMFoam |
December 11, 2013, 07:08 |
NaiXian Leslie Lu
Hi Foamers,
I am working on a simple 2D case that flow passes by a channel with one side of the channel wall being concave. Flow goes in from the bottom and goes out from the top. The concave wall is fixed and the left flat wall is moving towards the concave wall. I have specified: Pressure: outlet fixed at 1 bar, zeroGradient for others; Velocity: flowRateInletVelocity 1e-05 at the inlet, pressureInletOutletVelocity at the outlet, fixed value 0 at the concave wall, and movingWallVelocity at the moving wall; I used compressibleInterFoam for my injection simulation. Therefore I do my moving mesh test based on this solver. Here the fluid is water (although I still call it gasoline...), and I have switched off the compressibility by setting psi = 0. First test no mesh motion, pointMotionUx = 0, mass conservation is fine. Here is an extract of the log file Courant Number mean: 0.000352001 max: 0.00046794 deltaT = 2e-05 Time = 0.0067 DICPCG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 0 Execution time for mesh.update() = 0.01 s time step continuity errors : sum local = 1.14092e-10, global = 1.14034e-10, cumulative = -2.17556e-06 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.96484e-06, No Iterations 5 time step continuity errors : sum local = 1.4302e-15, global = -1.4698e-16, cumulative = -2.17556e-06 --> FOAM Warning : From function cubeRootVolDelta::calcDelta() in file cubeRootVolDelta/cubeRootVolDelta.C at line 52 Case is 2D, LES is not strictly applicable PIMPLE: iteration 1 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.28786e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 1.2972e-05, Final residual = 1.71303e-14, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.00117604, Final residual = 2.75328e-06, No Iterations 2 max(U) 0.0499816 min(p_rgh) 99999.4 PIMPLE: iteration 2 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.28786e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 7.40712e-06, Final residual = 5.33731e-15, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.9535e-05, Final residual = 6.37423e-08, No Iterations 3 max(U) 0.0499816 min(p_rgh) 99999.4 PIMPLE: iteration 3 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.28786e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 7.26948e-06, Final residual = 5.15672e-15, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 5.26857e-06, Final residual = 2.05796e-08, No Iterations 2 max(U) 0.0499816 min(p_rgh) 99999.4 ExecutionTime = 13.05 s Courant Number mean: 0.000352 max: 0.000467942 deltaT = 2e-05 Time = 0.00672 DICPCG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 0 Execution time for mesh.update() = 0.01 s time step continuity errors : sum local = 1.13852e-10, global = 1.13793e-10, cumulative = -2.17545e-06 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.96323e-06, No Iterations 5 time step continuity errors : sum local = 1.42864e-15, global = -1.46837e-16, cumulative = -2.17545e-06 --> FOAM Warning : From function cubeRootVolDelta::calcDelta() in file cubeRootVolDelta/cubeRootVolDelta.C at line 52 Case is 2D, LES is not strictly applicable PIMPLE: iteration 1 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.28786e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 1.32896e-05, Final residual = 1.7448e-14, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.00117269, Final residual = 2.75305e-06, No Iterations 2 max(U) 0.0499818 min(p_rgh) 99999.4 PIMPLE: iteration 2 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.28786e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 7.50453e-06, Final residual = 5.21501e-15, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.94767e-05, Final residual = 6.45389e-08, No Iterations 3 max(U) 0.0499818 min(p_rgh) 99999.4 PIMPLE: iteration 3 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.28786e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 7.29273e-06, Final residual = 5.1861e-15, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 5.25134e-06, Final residual = 2.06509e-08, No Iterations 2 max(U) 0.0499818 min(p_rgh) 99999.4 ExecutionTime = 13.08 s Second test, pointMotionUx = 0.2, mass is not conserved. Courant Number mean: 0.0128567 max: 0.0207858 deltaT = 2e-05 Time = 0.0067 DICPCG: Solving for cellMotionUx, Initial residual = 4.419e-07, Final residual = 9.74887e-09, No Iterations 12 Execution time for mesh.update() = 0.01 s time step continuity errors : sum local = 0.000138757, global = 0.000138757, cumulative = 0.0905193 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.55594e-06, No Iterations 7 time step continuity errors : sum local = 0.000138771, global = 0.000138771, cumulative = 0.0906581 --> FOAM Warning : From function cubeRootVolDelta::calcDelta() in file cubeRootVolDelta/cubeRootVolDelta.C at line 52 Case is 2D, LES is not strictly applicable PIMPLE: iteration 1 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.9762e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0.00238355, Final residual = 2.36096e-12, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000295135, Final residual = 1.29158e-06, No Iterations 2 max(U) 2.03828 min(p_rgh) 99515.3 PIMPLE: iteration 2 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.95399e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 2.86226e-07, Final residual = 4.05804e-11, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 7.16766e-05, Final residual = 5.46045e-07, No Iterations 3 max(U) 2.03828 min(p_rgh) 99514.4 PIMPLE: iteration 3 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -1.93179e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 9.52316e-09, Final residual = 9.52316e-09, No Iterations 0 GAMGPCG: Solving for p_rgh, Initial residual = 1.78146e-05, Final residual = 8.30045e-08, No Iterations 2 max(U) 2.03828 min(p_rgh) 99514.7 ExecutionTime = 14.46 s Courant Number mean: 0.0128578 max: 0.0207894 deltaT = 2e-05 Time = 0.00672 DICPCG: Solving for cellMotionUx, Initial residual = 4.42075e-07, Final residual = 9.59846e-09, No Iterations 12 Execution time for mesh.update() = 0.01 s time step continuity errors : sum local = 0.000138776, global = 0.000138776, cumulative = 0.0907968 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.71665e-06, No Iterations 7 time step continuity errors : sum local = 0.00013879, global = 0.00013879, cumulative = 0.0909356 --> FOAM Warning : From function cubeRootVolDelta::calcDelta() in file cubeRootVolDelta/cubeRootVolDelta.C at line 52 Case is 2D, LES is not strictly applicable PIMPLE: iteration 1 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -2.13163e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 0.00237817, Final residual = 2.35453e-12, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000361452, Final residual = 1.39167e-06, No Iterations 2 max(U) 2.03827 min(p_rgh) 99514.7 PIMPLE: iteration 2 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -2.10942e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 2.84647e-07, Final residual = 4.18919e-11, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 8.95334e-05, Final residual = 6.61969e-07, No Iterations 3 max(U) 2.03827 min(p_rgh) 99513.9 PIMPLE: iteration 3 MULES: Solving for alphaGasoline Liquid phase volume fraction = 1 Min(alpha1) = 1 Min(alpha2) = -2.10942e-14 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 7.85789e-09, Final residual = 7.85789e-09, No Iterations 0 GAMGPCG: Solving for p_rgh, Initial residual = 2.31585e-05, Final residual = 7.22024e-08, No Iterations 2 max(U) 2.03827 min(p_rgh) 99514.2 ExecutionTime = 14.5 s When I run this setup with pimpleDyMFoam, mass is conserved too. Is there a bug here? Your comments and help are mostly welcome! Cheers, Leslie
Cheers, Leslie LU |
December 11, 2013, 09:44 |
NaiXian Leslie Lu
In fact it's the same problem with interDyMFoam. Is it a general problem of the multiphase solvers?
Cheers, Leslie LU |
December 18, 2013, 09:56 |
NaiXian Leslie Lu
The bug locates in pEqn.H
surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) - fvc::meshPhi(rho,U) + fvc::ddtPhiCorr(rAU, rho, U, phi) ); phi = phiHbyA;
Cheers, Leslie LU |
March 27, 2014, 04:52 |
Henry Weller mentioned on your bug report[0001110]: "Resolved by commit f3639a9c9d2baed720f2890e819f17af92a03a23"
What does it mean? Is the problem fixed in the last OF version? |
July 21, 2015, 04:05 |
Werner
Rep Power: 12 |
I ran into the same problem by using openfoam extend 3.1.1. I tried to make the implementation of the mesh motion. The mass in the system is now constant so that is fine, but now i have instabilities due to high internal residuals. As mentioned that implementation is not sufficient, but is there an easy possibility to fix that problem in the pEqn in openfoam extend. Out of the architecture of openfoam 2.4. i fail to implement the changes in my solver in openfoam 3.1.1.
DPM mass problem | Henrik Ström | FLUENT | 9 | May 20, 2016 11:00 |
Problem with changing mass flow rate | roo | FLUENT | 3 | June 4, 2013 14:53 |
problem of mass conservation with buoyantBoussinesqSimpleFoam | david89 | OpenFOAM Running, Solving & CFD | 1 | May 27, 2013 07:20 |
Mass conservation in VOF steady state | deepak7937 | FLUENT | 0 | November 21, 2011 06:58 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 14:06 |
