March 28, 2017, 08:39 |
How to change the Reynold's number?
Jem
Rep Power: 9 |
Hello, im using the channel395 file and need to make several simulations with different reynoldnumbers. How do i Change the reynold's number?
I figured i can Change the Ubar and the reynolds number will Change, but what is the correlation between Ubar and Re? Is there another way to Change Re? Thank you for help! |
March 28, 2017, 12:47 |
Tobias Holzmann
Rep Power: 51 |
I don´t know what you want to do but the definition of the Reynoldsnumber should be known: And based on that equation, you can see how to change the Reynoldsnumber. Further information are here: http://bfy.tw/AtyL But if this is not what you want to Do, I am sorry for the wrong Information.
Keep foaming, Tobias Holzmann Last edited by Tobi; March 28, 2017 at 14:03. |
March 28, 2017, 13:12 |
Agustín Villa
Rep Power: 15 |
I think there are expressions to relate them, but I'd go to the Re_tau definition. In your case, Re_tau=395. If you know the Re_tau definition, you can see how u_tau evolves, and then you can impose a certain pressure gradient, instead of the mean velocity. |
March 29, 2017, 04:35 |
Jem
Rep Power: 9 |
Hello Tobi!
your equation is exactly what im working with: Re_tau = u_tau * L / v. I wanna change u_tau in order to Change Re_tau. The Problem is, in order to Change u_tau i Need to Change Ubar. But what is the relation of Ubar to u_tau? Or what is the relation of Ubar to Re_tau? Do you have an equation? I tried to make one out of Literatur but the results are not correct: Ubar = 5,5 + (Re_tau*v)/delta * (2,44*lnRe_tau -2,4) Do you have a correct equation? |
March 29, 2017, 04:58 |
Jem
Rep Power: 9 |
Hello agustinvo!
The channel395 has cyclic boundaries. There are no inlet and outlet therefore you cant impose a pressure gradient. |
March 29, 2017, 05:59 |
Agustín Villa
Rep Power: 15 |
Of course you can! Take alook into SemiImplicitSource fvOption. Then you only change yout u_tau, and add the pressure gradient in the fvOption, change the mesh resolution and run the case
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Change density; reynolds number | thiez03 | CFX | 4 | April 5, 2012 17:04 |
