right solver for externalWallHeatFluxTemperature |
December 26, 2013, 19:37 |
Nestor Rueda
Rep Power: 17 |
Hi All,
I'm trying to simulate a heat transfer problems using heat transfer coefficients. It seems that the right choice is to use externalWallHeatFluxTemperature BC. I have been trying different solvers for this condition without any success. Any hint about the right solver for this BC? Regards |
December 27, 2013, 22:58 |
Nestor Rueda
Rep Power: 17 |
ok, after some trials it's more or less working.
This bc is for compressible solvers (e.g. buoyantSimpleFoam). A good example to try this BC is the hotRoom tutorial under heatTransfer > buoyantSimpleFoam > hotRoom. Try modifying one of the T boundaries. The structure is as follows: { type externalWallHeatFluxTemperature; Ta uniform 353; h uniform 3; //heat transfer coeff. kappa fluidThermo; kappaName default; value uniform 300; // initial temp. } however after some iterations I'm getting a fatal error: --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. has anyone tried this BC and overcomed this error? I'll keep working on it and post any advance. Regards, |
March 6, 2015, 11:12 |
Laurent DASTUGUE
Rep Power: 12 |
i have the same problem. Moreover, in my results i can see that the temperature has values which are huge like 3e+22 before the job crashes. Any advance in this problem ? Best regards, Laurent |
Fluent Adjoint Solver? | ex10148 | FLUENT | 16 | September 28, 2018 08:11 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
