Extracting Reaction Rates OF20x
Like Tree1Likes
  • 1 Post By ahcai007
Old   January 11, 2014, 02:10
Default Extracting Reaction Rates OF20x
Ah Cai
ahcai007 is on a distinguished road
I am using the tutorial dieselFoam with its global n-heptane mechanism to simulate diesel combustion. I wanted to output the reaction rates for CO2 as the fuel combusts. I checked that in basicChemistryModel.H and found that RR() refers to Reaction rates. However, when I type "chemistry.RR()" it does not work.
If I write it this way where I include the chemistry.RR() in a for loop.
PHP Code:
forAll (celli)
scalarField rr=chemistry.RR(celli);
Info<< "Reaction rate = " << rr << endl << endl;
it will produce a results as seen in log.txt.
If I were to write it as such:
PHP Code:
forAll (celli)
Info<< "Reaction rate = " << rr[3] << endl << endl;
it will produce an output as seen in log2.txt.
My guess is that "rr" will output the reaction rates of ALL the species at ALL the cells while "rr[3]" will only output the reaction rates of ALL the species at cell[3].
What I had in mind is to extract only the RR for one of the species (for my case, CO2) over all the cells.
Thanks.
Ahcai
Kummi likes this.
ahcai007 is offline   Reply With Quote
Old   January 13, 2014, 14:09
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
The RR in basicChemistryModel is a virtual function and is implemented later, in ODEChemistry (this isn't immediately obvious, but by looking at the thermyphysicalType in the thermphysicalProperties file you can see it). It also returns a scalar field, which is why you are able to initialize rr in both cases. If you look at ODEChemistryModelI.H at line 71, what RR(const label i) actually does is return the reation rate for species i.
In both cases, rr contains the entire RR field for whatever species happens to be in index cellI. Since Y is a PtrList for scalarfields, what you are actually doing is stepping through all 5 species. Have a look at YEqn.H to see what I mean. In the first case, you are returning the entire RR field for each species (for each iteration, you should see 5 outputs of "Reaction Rate". In the second, you are obtaining the reation rate for each species at cell index 3 (again, you have 5 outputs corresponding to the 5 species).
What you need to find is the index of CO2 in your thermo setup, then call chemistry.RR(CO2 index), which will give what you are looking for.
mturcios777 is offline   Reply With Quote
Old   January 27, 2014, 04:07
Ah Cai
Hi Marco,
Thanks for the explanation. It helped a lot and I manage to make it work =)
Cheers~
Old   June 2, 2016, 12:01
Mr.liu
lx882211 is on a distinguished road
Originally Posted by ahcai007 View Post
Hi Marco,
Cheers~
I meet a problem in Openfoam 2.3.0, reactingFoam, i need the data of CH4 reaction rate in contour(figure), but i failed to autowrite it like U or Yi.
First i added this code in the CreatField.H,
volScalarField Rrate
IOobject
"Rrate",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("Rrate", dimMass/dimVolume/dimTime, 0.0)
Then, i added this code in YEqn,
forAll(Y, i)
if (Y[i].name() != "CH4")
RR = reaction->R(Yi);
After wmake, it shows
YEqn.H:26:14: error: no match for ‘operator=’ (operand types are ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ and ‘Foam::tmp<Foam::fvMatrix<double> >’)
Rrate = reaction->R(Yi);
Can you tell me how to do that? Thank you very much.
lx882211 is offline   Reply With Quote
dieselfoam, reaction rate
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
combustion - reaction rates - urgent help needed siri Main CFD Forum 2 March 3, 2007 12:25
EDC l- Reaction Rates are Zero for some Reactions Atul FLUENT 2 October 7, 2005 10:38
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
Reaction rates Szasz Robert FLUENT 1 May 10, 2000 06:06
