Divergent temperature in chtMultiRegion(Simple)Foam
Old   January 29, 2014, 04:43
Default Divergent temperature in chtMultiRegion(Simple)Foam
akrasemann
akrasemann is on a distinguished road
first of all a summary of my installed software:
Ubuntu 13.10
OpenFOAM 2.2.2
ParaView 3.12.0
enGrid 1.4.0
What I would like to achieve is a set up capable of assessing both heat transfer (conduction, convection and radiation) and flow in a rather complex structure. In best case a 3D steady state model as well as a 3D transient model will be achieved.
Starting from both the tutorial cases 'multiRegionHeater' for the transient and steady state version of the chtMultiRegion-solver, I'm in the process of adapting the set up to my own needs, but useing a plane wall (and neglecting radiation) in order to link results to analytical solutions in a first step. By doing that I face the issue that my temperatures do not converge and causes the solver to stop with the following error:
[2] --> FOAM FATAL ERROR:
[2] Maximum number of iterations exceeded
[2]
[2]     From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Maximum number of iterations exceeded
[3]
[3]     From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
[3]     in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
[3]
FOAM parallel run aborting
By using the search function within this forum I got several hints on solving this issue:
  • Mesh quality
  • Boundary and initial conditions
  • Changing the number of iterations within the called function (not recommended)
In the following a description of what I was doing:
https://www.dropbox.com/s/x7b35dsaj6ao6r7/Geometry.pdf
As I set it up as a 3D case, although I am aware that for this problem a 2D case is sufficient, apart from the depicted patches (in red) there are <regionname>_front and <regionname>_back patches.
Regarding the mesh:
The mesh is generated in enGrid (1.4.0) and then exported to OpenFOAM using the OpenFOAM (polyhedral) export function. My mesh related questions were already answered by wyldckat: http://www.cfd-online.com/Forums/eng...gion-case.html
I am aware that a mesh generated by the blockMesh utility would suit that problem very well, but as I would like to go to a more complex structure, I try using the same process of setting up the case as I would do for future application. Due to the straightforward boundary layer refinement implemented in enGrid I would like to follow that path.
What is important to note is that by using the enGrid export function, the OpenFOAM set up does not follow the process of splitMeshRegions and changeDictionaryDict to account for multiple regions.
Regarding Boundary and initial conditions:
As I'm using a k-epsilon turbulence model, I had a look at http://www.cfd-online.com/Tools/turbulence.php, the referred explanations on the single entities that are used for calculating k and epsilon as well as the OpenFOAM user guide, which explains on these within section 2.1.8 (Lid driven cavity flow tutorial).
I ended up with the following equations:
k = 3/2*(sqrt(U_x^2 + U_y^2 + U_z^2)*I)^2, where U_i are the mean flow velocities and I is the turbulence intensity
epsilon = (C_mu^(0.75)*k^(1.5))/(l_t), where C_mu is a constant (0.09) and l_t is the turbulent length scale, which needs to be estimated.
For the plane wall case I use l_t = L_char * 0.4*delta, where L_char is a characteristic length (1.5m x-dimension) and delta the boundary layer thickness (4.91*L_char/sqrt(Re_x))
I then set up the case using the derived k and epsilon values, according to the geometry, fluid properties and individual flow. Interestingly I face the reported error in the laminar region (U=0.1, U=1), but a turbulent case (U=10) works fine:
https://www.dropbox.com/s/si9y50brwc...ady_U10.tar.gz
Increasing the velocity to U=50 causes again troubles.
None of the transient settings worked out:
https://www.dropbox.com/s/gj62ozuik5...ent_U10.tar.gz
To resolve that i had a closer look at http://openfoamwiki.net/index.php/Ge..._-_planeWall2D and the OF2.2 case. I ran the provided case (U0.1) without any troubles. Even U=1 without changing k and epsilon worked fine. Switching to a turbulent scenario (U=10) and applying the above mentioned equations to the scenario produced a solution.
By the way I adapted the tutorial for running it in parallel. Please check the ChangeLog:
https://www.dropbox.com/s/wwxv9y7zzi...arallel.tar.gz
I realized that the k and epsilon values for the laminar region differs enormously from mine, so I used these values for my own set up, but again the solver crashes due to divergent temperature solutions, as stated above.
So I really am confused about how to set the case. I also do not see big differences in the boundary and initial conditions after looking at them for two days. All fvSolution and fvSchemes are exactly the same.
Sorry for the lengthy explanation, but I'm happy to share my documentation with the community after I resolved these issues.
Greetings,
Andreas
akrasemann is offline   Reply With Quote
Old   January 29, 2014, 05:48
Olivier
olivierG is on a distinguished road
hello,
Did you check where your temperature drop rise to the limit ?
Because i suspect that you get bad temperature value at wall boundary, using turbulence k-e model.
If this is the case, you may try to check / modify your wall BC (turbulence, mut, T).
In some case, switching to another (adapted) turbulence model may solve your trouble. Another way is to switch back to 1order upwind for turbulence and temperature, and use limiter.
Anyway, if you find a better solution, don't hesitate to post here.
Regards,
olivier
olivierG is offline   Reply With Quote
Old   January 29, 2014, 11:05
akrasemann
Hi Oliver,
thank you very much for your hints. Indeed the issues occur within the boundary layer. What I am surprised about is that in the 2D Wiki cases everything works fine. As soon as I use my mesh (3D) and the same settings as in the 2D Wiki cases including the front and back faces as symmetryPlane the solver crashes in all cases except when U=10.
Does the additional dimension influence the turbulence model that much? I am aware that turbulent flows are much more complex in 3D but I thought the model could handle that.
You are suggesting to switch to another turbulence model. What exactly are you thinking of? A k-omega-STT model?
Andreas
Old   January 29, 2014, 11:35
Olivier
I faced once this use, but i don't remember how i solved this. This clearly come from the boundary layer, which i suspect to not behave well with temperature gradient, thus viscosity/density gradient.
Try to switch from k-e realizable to RNG or the opposite, or kwSST.
Check also your mut BC (? try the mutSpaldingWallFunction).
Anyway if you find the root of this issue, post it.
regards,
olivier
Old   January 30, 2014, 09:55
akrasemann
I've tried now the following turbulence models:
  1. kEpsilon
  2. kOmegaSST
  3. RNGkEpsilon
  4. realizableKE
neither of them could produce a solution. Critical cells are within the boundary layer close to the outlet.
Additionally I tried both mutUWallFunction and mutUSpaldingWallFunction, but both were unsuccessful.
I really wonder that there is no solution to this issue as I see several threads in this forum discussing this particular error. Unfortunately all provided tutorials run in a laminar case. But I assume that a lot of heat transfer problems are related to turbulent flows. So I guess more people would have faced this before.
Old   January 30, 2014, 10:12
Olivier
hello,
Did you check if you have T oscillation in this boundary layer ? or temperature just rise ?
- What is your Y+ ?
- try to relax more T eq.
- try to initialise with constant properties (density, viscosity, ...)
- try SA turbulence model.
What is you outlet BC (T and velocity/pressure). if you got a spot in pressure at outlet, this can explain the instability.
regards,
olivier
Old   January 31, 2014, 04:44
akrasemann
Hi Olivier,
thanks again for your input!
By looking at the minT values within the log file, I see that that value is oscillating but dropping in a general trend. What is interesting: the amplitude is in the beginning not that big (at most 50K) but right before the solver crashes the temperature value drops by more than 250K.
To answer the Y+ question: I used the formulas given on http://www.cfd-online.com/Wiki/Y_plu...nce_estimation but rearranged the last equation for y+. For the y input I used the height of the very first cell at the wall boundary. So I get a y+ = 46. I'm not sure whether my understanding here is right.
With respect to the BC for the cold region:
alphat
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alphat;
dimensions      [1 -1 -1 0 0 0 0];
value        0;
internalField   uniform  $value;
boundaryField
    c_left
        type            calculated;
        value           uniform  $value;
    c_right
        type            calculated;
    s_bottom_cold
        type            compressible::alphatWallFunction;
        Prt             0.85;
    c_front
        type            symmetryPlane;
    c_back
        type            symmetryPlane;
    c_bottom
        type            symmetryPlane;
epsilon
FoamFile
    version     2.0;
    format      ascii;
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
value        19.09;
boundaryField
    c_left
        type            inletOutlet;
        inletValue      uniform  $value;
    c_right
        type            fixedValue;
    s_bottom_cold
        type            compressible::epsilonWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
    c_front
        type            symmetryPlane;
    c_back
        type            symmetryPlane;
    c_bottom
        type            symmetryPlane;
k
FoamFile
    version     2.0;
    format      ascii;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
value        0.375;
boundaryField
    c_left
        type            inletOutlet;
    c_right
        type            fixedValue;
    s_bottom_cold
        type            compressible::kqRWallFunction;
    c_front
        type            symmetryPlane;
    c_back
        type            symmetryPlane;
    c_bottom
        type            symmetryPlane;
mut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      mut;
value        0;
boundaryField
    c_left
        type            calculated;
    c_right
        type            calculated;
    s_bottom_cold
        type            mutUSpaldingWallFunction;//mutUWallFunction;
    c_front
        type            symmetryPlane;
    c_back
        type            symmetryPlane;
    c_bottom
        type            symmetryPlane;
p
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
value           1e5;
boundaryField
        type            calculated;
    c_front
        type            symmetryPlane;
    c_back
        type            symmetryPlane;
    c_bottom
        type            symmetryPlane;
p_rgh
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
value           1e5;
boundaryField
    c_left
        type            fixedValue;
    c_right
        type            fixedFluxPressure;
    s_bottom_cold
    c_bottom
    type            symmetryPlane;
    c_front
    type            symmetryPlane;
    c_back
    type            symmetryPlane;
T
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
value           293.15;
boundaryField
    c_left
        type            fixedValue;
    c_right
        type            zeroGradient;
    s_bottom_cold
            type            compressible::turbulentTemperatureCoupledBaffleMixed;
                neighbourFieldName T;
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 293.15;
    c_bottom
    type            symmetryPlane;
    c_front
    type            symmetryPlane;
    c_back
    type            symmetryPlane;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
value           (50 0 0);
internalField   uniform (50 0 0);
boundaryField
    c_left
        type            fixedValue;
    c_right
        type            inletOutlet;
        inletValue      uniform (50 0 0);
        value           uniform (50 0 0);
    s_bottom_cold
        type            fixedValue;
        value           uniform (0 0 0);
    c_bottom
    type            symmetryPlane;
    c_front
    type            symmetryPlane;
    c_back
    type            symmetryPlane;
For the shell region:
p
FoamFile
    version     2.0;
    format      ascii;
    object      p;
value        1e5;
boundaryField
    s_left
        type            calculated;
    s_right
        type            calculated;
    s_top_shell
        type            calculated;
    s_bottom_shell
        type            calculated;
    s_front
        type            symmetryPlane;
    s_back
        type            symmetryPlane;
T
FoamFile
    version     2.0;
    format      ascii;
    object      T;
value           443.15;
boundaryField
    s_left
        type            zeroGradient;
    s_right
        type            zeroGradient;
    s_top_shell
        kappa           solidThermo;
        kappaName       none;
    s_bottom_shell
        kappa           solidThermo;
        kappaName       none;
    s_front
    type            symmetryPlane;
    s_back
    type            symmetryPlane;
The hot region is just like the cold but the wall is on opposite side.
By setting the thermophysicalProperties as follows, I thought I would end up with constant properties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant/bottomAir";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        nMoles          1;
        molWeight       28.9;
    thermodynamics
        Cp              1000;
        Hf              0;
    transport
        mu              1.8e-05;
        Pr              0.7;
In fact my flow in the end should include temperature dependent properties as I will heat air from 600 to 1000K and density changes are quite big in that region.
What I have been trying yesterday was to extrude the mesh at the inlet to account for a developed boundary layer as soon as the flow hits the shell interface. I did this because I thought that it might be that I get a transition zone at the outlet. But unfortunately this didn't help.
I will now take a look at the SA turbulence model and relaxation factors.
Regards,
Andreas
Old   February 1, 2014, 11:01
Michael Page
micpage18 is on a distinguished road
I got a problem similar than yours.
To get convergence, I started the simulation with laminar model. After 50 iterations, I copied new turbulence files (k, omega, mut, etc...) in the time folder a I activated my turbulence model. The model converge after that.
Good luck,
Michael Page
michael.page@simu-k.com
Simu-K inc.
www.simu-k.com
micpage18 is offline   Reply With Quote
Old   February 3, 2014, 03:12
Olivier
hello,
Seem that your trouble came from your BCs.
You use fixedValue for both velocity and pressure. You should _never_ do that.
Regards,
olivier
Old   February 4, 2014, 03:06
akrasemann
Hi Michael,
Hi Olivier,
thank you for your advice. Olivier was right. The pressure BC caused the trouble. The hint, to start off a laminar solution will be useful soon.
Still all the investigating the root cause of the error taught me a lot on how to deal with OF and CFD itself. Thanks again for all your input.
I ran a few test cases and for now it seems that a k-epsilon RNG model is the most stable one.
Greetings,
Andreas
Old   March 19, 2014, 13:21
Pam
prameelar is on a distinguished road
Originally Posted by akrasemann View Post
Hi Michael,
Hi Olivier,
Greetings,
Andreas
Hi Andreas,
I am also facing the same problem with chtMultiRegionSimpleFoam and Laminar case. Could you please share your BC files if possible for my reference.
Thank you,
Pam
prameelar is offline   Reply With Quote
Old   March 20, 2014, 04:15
akrasemann
Hi Pam,
here are my changeDictionaryDict files:
region cold:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      changeDictionaryDict;
dictionaryReplacement
     boundary
          c_front
                type      symmetryPlane;
          c_back
                type      symmetryPlane;
          c_bottom
                type      symmetryPlane;
     U
          internalField      uniform (0.0099585 0 0);
          boundaryField
               c_left
                    type      fixedValue;
                    value      uniform (0.0099585 0 0);
               c_right
                    type      inletOutlet;
                    inletValue      uniform (0 0 0);
               cold_to_shell
                    type      fixedValue;
               c_front
                    type      symmetryPlane;
               c_back
                    type      symmetryPlane;
               c_bottom
                     type      symmetryPlane;
               ce_top
                     type      slip;
     T
          internalField      uniform 293.15;
          boundaryField
               c_left
                    type      fixedValue;
               c_right
                    type      zeroGradient;
               cold_to_shell
                    kappa      fluidThermo;
                    kappaName      none;
               c_front
                    type      symmetryPlane;
               c_back
                    type      symmetryPlane;
               c_bottom
                     type      symmetryPlane;
               ce_top
                     type      zeroGradient;
     epsilon
          internalField      uniform 0.01;
          boundaryField
               c_left
                    type      fixedValue;
                    value      uniform 0.01;
               c_right
                    type      inletOutlet;
                    inletValue      uniform 0.01;
                    value      uniform 0.01;
               cold_to_shell
                    Cmu      0.09;
                    kappa      0.41;
                    E      9.8;
                    value      uniform 0.01;
               c_front
                    type      symmetryPlane;
               c_back
                    type      symmetryPlane;
               c_bottom
                     type      symmetryPlane;
               ce_top
                     type      zeroGradient;
     k
          internalField      uniform 0.1;
          boundaryField
               c_left
                    type      fixedValue;
                    value      uniform 0.1;
               c_right
                    type      inletOutlet;
                    inletValue      uniform 0.1;
                    value      uniform 0.1;
               cold_to_shell
                    value      uniform 0.1;
               c_front
                    type      symmetryPlane;
               c_back
                    type      symmetryPlane;
               c_bottom
                     type      symmetryPlane;
               ce_top
                     type      zeroGradient;
     p
          internalField      uniform 1e5;
          boundaryField
                    type      calculated;
                    value      uniform 1e5;
               c_front
                    type      symmetryPlane;
               c_back
                    type      symmetryPlane;
               c_bottom
                     type      symmetryPlane;
     p_rgh
          boundaryField
               c_left
                    type      zeroGradient;
               c_right
                    type      fixedValue;
                    value      uniform 1e5;
               cold_to_shell
                    value      uniform 1e5;
               c_front
                    type      symmetryPlane;
               c_back
                    type      symmetryPlane;
               c_bottom
                     type      symmetryPlane;
               ce_top
                    value      uniform 1e5;
region shell
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
     boundary
          s_front
                type      symmetryPlane;
          s_back
                type      symmetryPlane;
     T
          internalField      uniform 443.15;
          boundaryField
               s_left
                    type      zeroGradient;
               s_right
                    type      zeroGradient;
               shell_to_hot
                    kappa      solidThermo;
                    kappaName      none;
                    value      uniform 443.15;
               shell_to_cold
                    kappa      solidThermo;
                    kappaName      none;
               s_front
                    type      symmetryPlane;
               s_back
                    type      symmetryPlane;
     p
          boundaryField
               s_left
                    type      calculated;
                    value      uniform 1e5;
               s_right
                    type      calculated;
                    value      uniform 1e5;
               shell_to_hot
                    type      calculated;
                    value      uniform 1e5;
               shell_to_cold
                    type      calculated;
                    value      uniform 1e5;
               s_front
                    type      symmetryPlane;
               s_back
                    type      symmetryPlane;
region hot
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
     boundary
          h_front
                type      symmetryPlane;
          h_back
                type      symmetryPlane;
          h_top
                type      symmetryPlane;
     U
          boundaryField
               h_left
                    type      fixedValue;
               h_right
                    type      inletOutlet;
               hot_to_shell
                    type      fixedValue;
               h_front
                    type      symmetryPlane;
               h_back
                    type      symmetryPlane;
               h_top
                     type      symmetryPlane;
               he_bottom
                     type      slip;
     T
          internalField      uniform 593.15;
          boundaryField
               h_left
                    type      fixedValue;
                    value      uniform 593.15;
               h_right
                    type      zeroGradient;
               hot_to_shell
                    kappa      fluidThermo;
                    kappaName      none;
               h_front
                    type      symmetryPlane;
               h_back
                    type      symmetryPlane;
               h_top
                     type      symmetryPlane;
               he_bottom
                     type      zeroGradient;
     epsilon
          boundaryField
               h_left
                    type      fixedValue;
                    value      uniform 0.01;
               h_right
                    type      inletOutlet;
                    value      uniform 0.01;
               hot_to_shell
                    Cmu      0.09;
                    kappa      0.41;
                    E      9.8;
                    value      uniform 0.01;
               h_front
                    type      symmetryPlane;
               h_back
                    type      symmetryPlane;
               h_top
                     type      symmetryPlane;
               he_bottom
                     type      zeroGradient;
     k
          boundaryField
               h_left
                    type      fixedValue;
                    value      uniform 0.1;
               h_right
                    type      inletOutlet;
                    value      uniform 0.1;
               hot_to_shell
                    value      uniform 0.1;
               h_front
                    type      symmetryPlane;
               h_back
                    type      symmetryPlane;
               h_top
                     type      symmetryPlane;
               he_bottom
                     type      zeroGradient;
     p
          boundaryField
                    type      calculated;
                    value      uniform 1e5;
               h_front
                    type      symmetryPlane;
               h_back
                    type      symmetryPlane;
               h_top
                     type      symmetryPlane;
     p_rgh
          boundaryField
               h_left
                    type      zeroGradient;
               h_right
                    type      fixedValue;
                    value      uniform 1e5;
               hot_to_shell
                    value      uniform 1e5;
               h_front
                    type      symmetryPlane;
               h_back
                    type      symmetryPlane;
               h_top
                     type      symmetryPlane;
               he_bottom
                    value      uniform 1e5;
From my experience, the laminar case is much more complex as one would assume. It is true that the physics are less complex in terms of eddies and vortices, but assigning 'laminar' in OpenFOAM implies that there is no turbulence model used for the viscous parts of the Navier-Stokes equations. This also means that the quality of the mesh is most important. I can recommend 'Boundary Layer Theory' by Schlichting and 'Turbulence Modelling for CFD' by Wilcox as a reference for getting an idea what happens there.
Apart from the mesh it happened also to me that due to the very slow flow in my domain, the buoyancy has a much bigger influence on the solution. Therefore consider switching off gravity by setting the gravity vector to (0 0 0) in constant/<fluidregions>/g
Andreas
Old   March 20, 2014, 12:26
Pam
Hi Pam,
Andreas
Thank you for your reply Andreas, I have tried all the options and was able to run for more timesteps then before but not the complete problem. I am attaching the log file of my simulation. Please have a look if you get chance.
Thanks again,
Kind regards,
Pam.
Pam
Old   March 24, 2014, 02:54
akrasemann
The log file doesn't include an error output. But your density min and max value are probably at the maximum that is allowed. This indicates some issues there.
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
