rhoSimplecFoam Diverges for External Flow
Old   January 31, 2014, 15:34
Default rhoSimplecFoam Diverges for External Flow
Sohail
sohailr is on a distinguished road
Hello guys,
I am trying to make a turbulent flow simulation over a wing using rhoSimplecFoam ver. OpenFOAM-2.0. I ran my case after 19 iteration I get an error message. After spending lots of time and many attempts I decided to open a tread in forum. Could someone help me where is the mistake in my boundary conditions or schemes..
I want to use kepsilon for turbulence modeling.
Here are by BC's
FoamFile
version 2.0;
format binary;
class volScalarField;
location "0";
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 79500;
boundaryField
outlet
type fixedValue;
value $internalField;
wing_winglet
type zeroGradient;
inlet
type zeroGradient;
refValue uniform 79500;
refGradient uniform 0;
valueFraction uniform 0.3;
farfield
type zeroGradient;// fixedValue;
// value $internalField;
root
type symmetryPlane;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (103 0 0);
outlet
type inletOutlet;
inletValue uniform (103 0 0);
farfield
type zeroGradient;//inletOutlet;
//inletValue uniform (0 0 0);
//value $internalField;
root
type symmetryPlane;
wing_winglet
type fixedValue;
value uniform (0 0 0);
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 278.8;
boundaryField
outlet
type zeroGradient;// inletOutlet;
// inletValue $internalField;
wing_winglet
type zeroGradient;
inlet
type fixedValue;
farfield
//inletValue $internalField;
root
type symmetryPlane;
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1.5913;
boundaryField
outlet
type inletOutlet;
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.1;
farfield
root
type symmetryPlane;
wing_winglet
type compressible::kqRWallFunction;
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 2.35;
boundaryField
outlet
type inletOutlet;
inletValue $internalField;;
inlet
type compressible::turbulentMixingLengthDissipationRate Inlet;
mixingLength 0.14;
farfield
// inletValue $internalField;;
root
type symmetryPlane;
wing_winglet
type compressible::epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value $internalField;;
object alphat;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 2e-5;
boundaryField
outlet
type calculated;
wing_winglet
type alphatWallFunction;
Prt 0.89;
inlet
type calculated;
farfield
type zeroGradient;//calculated;
root
type symmetryPlane;
object mut;
internalField uniform 1.4876e-5;
boundaryField
outlet
type calculated;
wing_winglet
type mutkWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
inlet
type calculated;
farfield
root
type symmetryPlane;
Here are my schemes and solutions dicts
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div((muEff*dev2(T(grad(U))))) Gauss linear;
div(phi,e) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phid,p) bounded Gauss upwind;
div(phi,Ekp) bounded Gauss upwind;
div((phi|interpolate(rho)),p) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
pCorr;
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-08;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 20;
agglomerator faceAreaPair;
mergeLevels 1;
"(U|e|k|epsilon)"
solver GAMG;
tolerance 1e-08;
relTol 0.1;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
SIMPLE
nNonOrthogonalCorrectors 0;
rhoMin rhoMin [1 -3 0 0 0] 0.1;
rhoMax rhoMax [1 -3 0 0 0] 1.0;
transonic yes;
residualControl
p 1e-3;
U 1e-4;
e 1e-3;
// possibly check turbulence fields
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 1;
rho 1;
equations
p 1;
U 0.9;
e 0.9;
k 0.9;
epsilon 0.9;
Any help will be appreciated.
Thanks
sohailr is offline   Reply With Quote
boundary conditions, cfd. openfoam, external flow, rhosimplecfoam, wing
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
