Understanding the cyclic boundary condition
Like Tree2Likes
  • 1 Post By snak
  • 1 Post By Ardali
Old   February 13, 2014, 09:54
Post Understanding the cyclic boundary condition
Vincent Leroy
leroyv is on a distinguished road
Dear foamers,
I need to solve problems with cyclic BCs 'all around the place'. To be clearer, this is the geometry I am considering:
https://www.dropbox.com/s/amuzikceam...nder_array.png
On this screenshot, the colouring is the velocity (U) magnitude, U being obtained using the simpleFoam solver and a uniform inlet BC on the x = 0 face. What I want to do is simply simulate the flow in the (6,4) cell using periodic boundary conditions:
https://www.dropbox.com/s/v5nz4mvx6user06/6-4_cell.png
Firstly, let's have a look at what we want to reproduce. Here are the velocity magnitude and orientation in the (6,4) cell (let's call this the reference problem):
https://www.dropbox.com/s/8eivt2e1ai...eference_U.png
This velocity field seems periodic. If we subtract a periodic field from this one, we should get another periodic field, maybe better as an evidence. So we do that and plot the so-called deviation field, UTilde, obtained by subtracting the volume average of U (which is constant over the cell) from U:
UTilde = U - UAverage
Here is what we get:
https://www.dropbox.com/s/8gnccd1pzy...nce_UTilde.png
This deviation field is periodic 'x-wise' and 'y-wise'.
I tried to simulate the flow in the (6,4) cell using the simpleFoam solver (though if might not be the best, AFAIK; anyway, this is not the worst problem here). I therefore simply applied cyclic patches at the boundaries of the cell. Although this insufficiently constraints the problem, the SIMPLE algorithm converges to a solution which only depends on the initial condition, yielding the following velocity field:
https://www.dropbox.com/s/rufn5k53mf...periodic_U.png
Given that image, we can doubt that this field is periodic. The deviation field gives a clearer proof:
https://www.dropbox.com/s/nf81rnnj4h...dic_UTilde.png
UTilde is not periodic, while it should be.
So here is my question: Is there any reason why the periodic BC wouldn't be satisfied in the cyclic problem? Did I do something wrong?
The associated OpenFOAM cases come attached. Screenshot gallery:
https://www.dropbox.com/sh/hmq2qx6jcvjc6lx/LFKCB1X32b
Last edited by leroyv; February 13, 2014 at 10:05. Reason: Corrected bad hyperlinks
leroyv is offline   Reply With Quote
Old   February 13, 2014, 12:08
Post Update
Vincent Leroy
I ran an additional simulation with a correctly constrained problem, replacing the inlet and outlet cyclic patches with regular inlet and outlet patches.
Inlet: zeroGradient pressure, fixedValue uniform velocity
Outlet: fixedValue uniform pressure, zeroGradient velocity
https://www.dropbox.com/s/38s9ap0ev5...periodic_U.png
The 'y-wise' periodicity is not satisfied either.
Old   February 14, 2014, 05:30
shinji nakagawa
snak is on a distinguished road
hi,
something in cyclic patch in your original case is wrong.
checkMesh shows some error.
Using createPatch fixed this problem.
a modified case with createPatchDict and modified Allrun is here,
singleCylinderPeriodic_simpleFoam_createPatch.zip
Periodic fields is obtained with this case. tested with OF222.
leroyv likes this.
snak is offline   Reply With Quote
Old   February 14, 2014, 12:38
Smile Problem solved
Vincent Leroy
Thank you very much! It seems like patch orientation is much more of a big deal than I expected.
Originally Posted by snak View Post
hi,
Attachment 28671
Old   March 20, 2014, 09:01
Vincent Leroy
Dear foamers,
I have an additional question about the cyclic boundary condition: what does it actually do? Does it ensure equality of fields and derivatives at the associated boundaries? Or does it only ensure equality of fields?
Old   May 29, 2020, 20:55
Arijit Saha
ari003 is on a distinguished road
Dear foamers,
Hi, I was also searching for some doc which contains the details of the cyclic bc but unfortunately there isn't enough. Did you get the answer to this? If so are you willing to share your understanding here?
ari003 is offline   Reply With Quote
Old   May 29, 2020, 23:15
Ardalan
Ardali is on a distinguished road
That is a simple idea. It recycle the quantity between two patches or planes! What is complex with the b.L.
Ardali is offline   Reply With Quote
Old   May 29, 2020, 23:24
Arijit Saha
Thanks for responding to my concern. Can you please elaborate with an example if possible?
Old   May 29, 2020, 23:27
Ardalan
yes, sure. For example the velocity on the outlet will be exactly mapped to the inlet. In other word, the length of the domain will be assumed infinity. You can see the channel395 tutorial for more details.
SHANRU likes this.
Old   May 30, 2020, 19:31
Arijit Saha
Yaa I understood that in cyclic boundary condition the patches have same physical behavior but specifically for this channel 395 case why do we need cyclic bc and why not some other kind of boundary condition?
Old   May 31, 2020, 09:05
Ardalan
Because you do not have entrance length in the channel. you want to have fully developed flow inside the channel. As I said before, you making the length infinity when you use cyclic bc.
cyclic bc, periodic bc, simplefoam
Cyclic boundary condition for dnsFoam antoinep76 OpenFOAM Programming & Development 7 March 18, 2013 04:54
cyclic boundary condition xxxx OpenFOAM Pre-Processing 2 March 16, 2013 02:25
cyclic boundary condition flotran OpenFOAM 3 December 19, 2011 20:13
Cyclic jump boundary condition hjasak OpenFOAM Running, Solving & CFD 10 April 16, 2010 15:35
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
