Single propeller blade in SRFSimpleFoam
Old   February 27, 2014, 14:51
Default Single propeller blade in SRFSimpleFoam
Mike
brownmj is on a distinguished road
Hello foamers!
I am running a single propeller blade using SRFSimpleFoam and periodic boundary conditions (cyclicAMI). My question has to do with the initial conditions of the flow. As far as I can tell, the only way to specify the initial conditions (for velocity, that is) is in the 0/Urel file, where all the velocities are, of course, relative.
For my inlet, far-field boundaries, I can use type=SRFVelocity and set relative=no in order to specify a uniform axial velocity (in the absolute reference frame). HOWEVER, I cannot figure out a way to input a uniform axial velocity in the absolute reference frame for the internalField. All I can do is set the RELATIVE velocity to (1 0 0), meaning that the initial condition for the flow is to be rotating with the propeller blade.
So, of course I'm having problems getting a converged solution and I think it could be because my initial condition is so far off from the physical solution.
Does anyone have any tips on how to input an initial condition of uniform velocity in the absolute frame to SRFSimplefoam?
In the meanwhile, I am running a case with very low RE# (~300). Hopefully all the extra viscosity will help the inlet and farfield BC's to decelerate all that rotating flow, and then I can update the RE# to a higher one once I get convergence. Any thoughts on this plan?
I've included my Urel file below, thanks for reading!
|  \\    /   O peration     | Version:  2.3.0                               |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      Urel.orig;
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (1 0 0);
boundaryField
    hub-6
        type            fixedValue;
        value           uniform (0 0 0);
    farfield-5
        type            SRFVelocity;
        inletValue      uniform (1 0 0);
        relative        no;
        value           uniform (1 0 0);
    blade-4
        type            fixedValue;
    periodic_sfc1-9
        type            cyclicAMI;
    periodic_sfc2-10
        type            cyclicAMI;
    outlet-8
        type            zeroGradient;
    inlet-7
        type            SRFVelocity;
        relative        no;
brownmj is offline   Reply With Quote
Old   March 4, 2014, 12:26
Mike
Hi guys,
I just wanted to report back that I have fixed my own issue. Running 4000 times steps at a high viscosity was enough to get a somewhat converged solution. I then changed back to the desired viscosity and ran another 2000. Now, the forces are looking good compared to the experiment.
A colleague also has been teaching me about SwAK4Foam, and we have been trying to get those codes compiled on my machine so that I can use them to set up better initial conditions. However, as of Friday 3/1/14, the SWAK source doesn't seem to be compatible with OF 2.3.0.
Old   March 4, 2014, 14:42
J. Brindley
oldirtybrindley is on a distinguished road
I am trying to simulate a Hydro-kinetic turbine blade. Could you share your case directory with me?
oldirtybrindley is offline   Reply With Quote
Old   April 22, 2014, 07:08
Default bc
Jiri
Jiricbeng is on a distinguished road
Hi brownmj,
would you mind uploading your files? I am struggling with similar issue.
Jiricbeng is offline   Reply With Quote
Old   August 6, 2014, 10:21
Ali
ashim is on a distinguished road
Good morning. I am trying to simulate the same case as Mike, one propeller blade with cyclic boundary at the two sides using SRFSimpleFoam. After few iterations the time step continuity error become high and stops the simulation with error message. I couldn't understand the reason behind it. I am trying solve it from the last two weeks. But no progress. I think I have messed up the boundary conditions and solver settings. Would you please help me providing hints / advice. Any kind of help is appreciated.
Ali
ashim is offline   Reply With Quote
Old   August 12, 2014, 14:40
Ye Zhang
kiddmax is on a distinguished road
Hi Ali,
I have the same problem. Did you solve your issue?
Best regards
Ye
kiddmax is offline   Reply With Quote
Old   August 13, 2014, 07:12
Ali
Hi Ye,
Still now, I couldn't solve the problem. I have figured out that pressure at some points is relatively high than others. The pressure calculation is not going in correct way. I am expecting some help from this forum. Can anyone please help me?
Best regards,
Ali
Old   August 14, 2014, 03:01
Ye Zhang
Hi Ali,
Thank you for your reply. I searched similar thread about SRFSimpleFoam, and what I conclude is that this solver maybe is not stable as MRFSimpleFoam. So I want to try MRFSimpleFoam and see what happens.
Kind regards,
Ye
Old   July 12, 2021, 09:55
Chakshu DEORA
chakshu is on a distinguished road
Hi Guys,
I know it has been a while on this post but any solution for the same problem? I am struggling with same issues, any kind of input is most welcomed.
I am trying to simulate a UAV propeller.
Thanks.
Regards.
chakshu is offline   Reply With Quote
Simulation flow through Propeller by SRFSimpleFoam baoaero OpenFOAM Running, Solving & CFD 14 July 5, 2021 11:44
[ICEM] Blocking of impeller single blade sector (MRF) delaneyluke ANSYS Meshing & Geometry 1 May 6, 2011 09:28
360 degree fluid zone for a 4 blade propeller s0me0ne CFX 5 June 27, 2010 07:09
propeller blade meshing Terence Fidelity CFD 8 July 15, 2008 13:31
Blade thickness on propeller wash prediction Lam Main CFD Forum 1 October 28, 2005 02:36
