Oscillating Pressure Gradient at the inlet
Like Tree1Likes
  • 1 Post By steezorigineez
Old   March 2, 2014, 10:26
Default Oscillating Pressure Gradient at the inlet
Harish Dixit
hdixit is on a distinguished road
Hello all,
I have a uniform inlet flow which is oscillating as U=U_{\infty} + A \sin(\omega t). If I use the continuity and the momentum equation, I get \partial u/\partial x=0. My x-momentum equation reduces to \partial p/\partial x = -\partial u/\partial t.
This gives me \partial p/\partial x = -A \omega \cos(\omega t). How do I put in such an oscillating pressure gradient at the inlet? I am looking for something along the lines of OscillatingFixedValue for inputting Dirchelet boundary conditions.
Please note that I have ignored (the constant) density in the above discussion since this can be absorbed in the case of incompressible Newtonian flow.
Thanks,
Harish
hdixit is offline   Reply With Quote
Old   October 10, 2014, 20:07
Nevada
razi.me05 is on a distinguished road
Hi Harish,
Did you get any solution to your problem? I'm facing exactly the same kind of problem.
razi.me05 is offline   Reply With Quote
Old   November 12, 2014, 18:14
Ian Pond
steezorigineez is on a distinguished road
Hi Guys,
I am currently simulating a pulsatile channel flow using a modified pimpleFoam solver. I am simulating a 2D periodic channel with a cosinusoidal pressure gradient. Using LaunderSharma KE turb model and the mesh is 256 in the wall normal direction and 8 in the axial direction. The inlet and outlet are set as cyclic BCs.
The way I have it set up now is I created a new solver by copying the pimpleFoam solver and adding a pressure gradient with a cosine term to the momentum equation in Ueqn.C. I believe this is the correct way to setup a flow with an oscillating pressure gradient.
I am having trouble in terms of convergence of the phases over each period at the moment.
Let me know if you have any thoughts or questions.
steezorigineez is offline   Reply With Quote
Old   November 16, 2014, 20:25
Ian Pond
Just wanted to update you and let you know that I was able to successfully get a pulsating channel running and the convergence issue is fixed. Let me know if you want the code.
-Ian
Old   May 26, 2015, 06:02
Default need code
SM
canopus is on a distinguished road
Hi Ian
Can you please share the code?
I have sent you a pm.
Regards
SM
canopus is offline   Reply With Quote
Old   May 26, 2015, 11:35
Ian Pond
Here is the git link to the code that I have used to successfully simulate a pulsating channel flow with an oscillating pressure gradient. It also includes the transport of scalar temperature. Let me know if you have any questions or comments.
https://github.com/ianbpond/pimpleFoamPulsTemp
canopus likes this.
Old   May 27, 2015, 18:24
Default questions
SM
Hi Ian
I checked out the code and could run it on the test case provided along with.
Sorry for stupid questions as this is my first brush with OF application development
1. I guess you are solving for U=U_{\infty} + A \sin(\omega t) where U_{\infty} = 0 ?
2. what does fvOptions(U) do in UEqn.h?
 fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U)
 ==    fvOptions(U) + dpdx*cos(Freq*runTime.time().value())
3.
is added as a source to momentum equation in UEqn.h and implies pressure gradient is set as 1/\rho( \partial p/\partial x) = -A \omega \cos(\omega t)?
4. Is -A/\rho \omega lumped together in dpdx which is set to 1 in constant/transportProperties? (dpdx sounds bit confusing)
5. constant/transportProperties:alphaPuls is not used ?
Thanks
SM
Old   May 27, 2015, 19:29
Ian Pond
Hi canopus,
1. I designed this code to match a DNS simulation which solves the Navier Stokes eqn in the following form.
\frac{\partial u_i}{\partial t} + u_j\frac{\partial u_i}{\partial x_j} = -\cos(\omega t) +\frac{1}{Re}\frac{\partial^2 u_i}{\partial x_j^2}
where \nu = 1/Re
2. The fvOptions(U) doesn't do anything as far as I know, I just left it in there. It could be removed I believe.
3. Yes that is the added source term which represents the -\cos(\omega t) in the above equation.
4. For our simulation \rho = 1, so the dpdx term is just an amplitude of the pressure, equal to 1 for our case, I don't have the extra \omega term as you do.
5. You are correct, alphaPuls is not used
Let me know if you still have questions.
Old   May 29, 2015, 11:32
SM
Thank you!
Could you please point to the DNS and your own work
in case they are available in public domain?
Old   June 8, 2015, 10:45
Ian Pond
Hi Canopus,
At the moment, the DNS data are not available in the pulbic domain. However, I will update when they do become available.
Old   June 26, 2015, 11:34
Ian Pond
I believe I may have an error in my referenced equation that is being solved. Sorry for any confusion. I will reply with the corrected equation soon.
Last edited by steezorigineez; June 26, 2015 at 11:39. Reason: Need to rewrite equation
Old   June 26, 2015, 13:50
Ian Pond
Please take note of an error in my original equation. It should be as follows.
\frac{\partial u_i}{\partial t} + u_j\frac{\partial u_i}{\partial x_j} = -\frac{dP}{dx} +\frac{1}{Re}\frac{\partial^2 u_i}{\partial x_j^2}
where,
-\frac{dP}{dx} = A \cos(\omega t)
with A = 1.
I apologize for any confusion.
Old   June 26, 2015, 19:47
Bernhard Linseisen
Linse is on a distinguished road
Concerning the fvOptions-part: If I am not mistaken, this is part of one of the latest flexibility additions in OpenFOAM. This entry looks for runTime-Code in the case structure. This way it is possible to add entries/source terms to the different equations without fully recompiling the code.
Please do not ask me further questions about this capability! I am right at the beginning of looking into it...
Linse is offline   Reply With Quote
icofoam, openfoam
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 01:12
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
BC: inlet pressure gradient val17lr FLUENT 2 July 6, 2010 03:49
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
