April 30, 2014, 07:53 |
problem with solving lagrange reaction cloud
Werner
Rep Power: 12 |
Hello to all!
I have the folowing problem: I simulate on OpenFOAM 2.2.2 an lagrance cloud which consists of ash, C, and C16H34 as a liquid. The evaporation i simulate with the liquid evapouration model. The simulation deals with particles which fly trough a hot gas and start to burn. The simulation runs perfect for the fist 10 000 interations but then i always get the following error message. I tried to reduce the timestep but this also not work. And one more strange thing, after the breakdown of the simulation, wenn i restart it from the last timestep i also get an error message. Below i poste the console output with the two last normal timesteps and the error message. After the error message i restartet the simulation and then there was the next error. Thank you for your help, yours Polli CONSOLE OUTPUT: Courant Number mean: 0.0008352037363 max: 0.02073954834 deltaT = 4.994994995e-08 Time = 0.00184316 Solving 3-D cloud coalCloud1 Cloud: coalCloud1 Current number of parcels = 200 Current mass in system = 3.536393974e-07 Linear momentum = (-2.329083518e-08 2.185374263e-08 -6.694384904e-08) |Linear momentum| = 7.41722859e-08 Linear kinetic energy = 5.237042721e-07 Rotational kinetic energy = 0 model1: number of parcels added = 200 mass introduced = 3.690682587e-07 Parcels absorbed into film = 0 New film detached parcels = 0 Parcel fate (number, mass) - escape = 0, 0 - stick = 0, 0 Temperature min/max = 309.6698539, 1321.440261 Mass transfer phase change = 1.542162181e-08 Mass transfer devolatilisation = 0 Mass transfer surface reaction = 7.23953612e-12 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 0.001104156049, Final residual = 9.873439027e-26, No Iterations 39 DILUPBiCG: Solving for Uy, Initial residual = 0.0005135342004, Final residual = 1.822588789e-26, No Iterations 40 DILUPBiCG: Solving for Uz, Initial residual = 0.0005317415987, Final residual = 9.042617802e-26, No Iterations 40 DILUPBiCG: Solving for CH4, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for C16H34, Initial residual = 1.11068148e-05, Final residual = 4.869725666e-09, No Iterations 1 DILUPBiCG: Solving for O2, Initial residual = 1.886436085e-05, Final residual = 5.272595733e-09, No Iterations 1 DILUPBiCG: Solving for H2, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for CO2, Initial residual = 2.05067378e-05, Final residual = 5.533931152e-09, No Iterations 1 DILUPBiCG: Solving for H2O, Initial residual = 2.049604594e-05, Final residual = 5.535477216e-09, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 1.869263163e-05, Final residual = 2.909299214e-26, No Iterations 39 T gas min/max = 312.9801108, 2822.970886 T gas min/max = 534.7538798, 948.6851826 T gas min/max = 312.9821183, 2822.878886 GAMG: Solving for p, Initial residual = 0.008959627278, Final residual = 9.390391906e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 8.316632968e-10, global = -4.769657762e-10, cumulative = -9.890697957e-08 GAMG: Solving for p, Initial residual = 1.105018814e-07, Final residual = 4.992748749e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.016364421e-11, global = -9.559535127e-13, cumulative = -9.890793552e-08 GAMG: Solving for p, Initial residual = 5.365688439e-09, Final residual = 5.365688439e-09, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.139834542e-11, global = -6.946863034e-13, cumulative = -9.890863021e-08 DILUPBiCG: Solving for epsilon, Initial residual = 5.823533933e-05, Final residual = 1.163355584e-26, No Iterations 38 DILUPBiCG: Solving for k, Initial residual = 0.0001720544673, Final residual = 9.004543255e-26, No Iterations 38 ExecutionTime = 22044.09 s ClockTime = 22890 s Courant Number mean: 0.0008349075938 max: 0.02088308343 deltaT = 4.994994995e-08 Time = 0.00184321 Solving 3-D cloud coalCloud1 [5] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [5] #1 Foam::sigFpe::sigHandler(int) at ??:? [5] #2 in "/lib64/libc.so.6" [5] #3 Foam::liquidMixtureProperties::X(Foam::Field<doubl e> const&) const at ??:? [5] #4 Foam::LiquidEvaporation<Foam::ReactingCloud<Foam:: ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam: :ReactingMultiphaseParcel<Foam::ReactingParcel<Foa m::ThermoParcel<Foam::KinematicParcel<Foam:article > > > > > > > > >::Tvap(Foam::Field<double> const&) const at ??:? [5] #5 void Foam::ReactingParcel<Foam::ThermoParcel<Foam::Kine maticParcel<Foam:article> > >::calcPhaseChange<Foam::ReactingParcel<Foam::Ther moParcel<Foam::KinematicParcel<Foam:article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam:article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam:article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam:article> > > > > > > > > >&, double, int, double, double, double, double, double, double, double, int, double, Foam::Field<double> const&, Foam::Field<double>&, double&, double&, double&, Foam::Field<double>&) at ??:? [5] #6 void Foam::ReactingMultiphaseParcel<Foam::ReactingParce l<Foam::ThermoParcel<Foam::KinematicParcel<Foam: article> > > >::calc<Foam::ReactingParcel<Foam::ThermoParcel<Fo am::KinematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > >&, double, int) at ??:? [5] #7 bool Foam::KinematicParcel<Foam: article>::move<Foam::ReactingParcel<Foam::ThermoPa rcel<Foam::KinematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > >&, double) at ??:? [5] #8 void Foam::Cloud<Foam::ReactingMultiphaseParcel<Foam::R eactingParcel<Foam::ThermoParcel<Foam::KinematicPa rcel<Foam: article> > > > >::move<Foam::ReactingParcel<Foam::ThermoParcel<Fo am::KinematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > >&, double) at ??:? [5] #9 void Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMul tiphaseParcel<Foam::ReactingParcel<Foam::ThermoPar cel<Foam::KinematicParcel<Foam: article> > > > > >::evolveCloud<Foam::ReactingParcel<Foam::ThermoPa rcel<Foam::KinematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > >&) at ??:? [5] #10 void Foam::KinematicCloud<Foam::Cloud<Foam::ReactingMul tiphaseParcel<Foam::ReactingParcel<Foam::ThermoPar cel<Foam::KinematicParcel<Foam: article> > > > > >::solve<Foam::ReactingParcel<Foam::ThermoParcel<F oam::KinematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam: article> > >::TrackingData<Foam::ReactingMultiphaseCloud<Foam ::ReactingCloud<Foam::ThermoCloud<Foam::KinematicC loud<Foam::Cloud<Foam::ReactingMultiphaseParcel<Fo am::ReactingParcel<Foam::ThermoParcel<Foam::Kinema ticParcel<Foam: article> > > > > > > > > >&) at ??:? [5] #11 [5] at ??:? [5] #12 __libc_start_main in "/lib64/libc.so.6" [5] #13 [5] at /home/abuild/rpmbuild/BUILD/glibc-2.18/csu/../sysdeps/x86_64/start.S:125 [linux-finq:07753] *** Process received signal *** [linux-finq:07753] Signal: Floating point exception (8) [linux-finq:07753] Signal code: (-6) [linux-finq:07753] Failing at address: 0x3e800001e49 [linux-finq:07753] [ 0] /lib64/libc.so.6(+0x358d0) [0x7f75efdfe8d0] [linux-finq:07753] [ 1] /lib64/libc.so.6(gsignal+0x39) [0x7f75efdfe849] [linux-finq:07753] [ 2] /lib64/libc.so.6(+0x358d0) [0x7f75efdfe8d0] [linux-finq:07753] [ 3] /opt/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libliquidMixtureProperties.so(_ZNK4Foam23liquidMix tureProperties1XERKNS_5FieldIdEE+0x243) [0x7f75f3fd9c63] [linux-finq:07753] [ 4] /opt/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/liblagrangianIntermediate.so(_ZNK4Foam17LiquidEvap orationINS_13ReactingCloudINS_11ThermoCloudINS_14K inematicCloudINS_5CloudINS_24ReactingMultiphasePar celINS_14ReactingParcelINS_12ThermoParcelINS_15Kin ematicParcelINS_8particleEEEEEEEEEEEEEEEEEE4TvapER KNS_5FieldIdEE+0x1c) [0x7f75f55036bc] [linux-finq:07753] [ 5] MycoalChemistryFoam4(_ZN4Foam14ReactingParcelINS_1 2ThermoParcelINS_15KinematicParcelINS_8particleEEE EEE15calcPhaseChangeINS6_12TrackingDataINS_23React ingMultiphaseCloudINS_13ReactingCloudINS_11ThermoC loudINS_14KinematicCloudINS_5CloudINS_24ReactingMu ltiphaseParcelIS6_EEEEEEEEEEEEEEEEvRT_didddddddidR KNS_5FieldIdEERSP_RdST_ST_SS_+0x82) [0x49f472] [linux-finq:07753] [ 6] MycoalChemistryFoam4(_ZN4Foam24ReactingMultiphaseP arcelINS_14ReactingParcelINS_12ThermoParcelINS_15K inematicParcelINS_8particleEEEEEEEE4calcINS7_12Tra ckingDataINS_23ReactingMultiphaseCloudINS_13Reacti ngCloudINS_11ThermoCloudINS_14KinematicCloudINS_5C loudIS8_EEEEEEEEEEEEEEvRT_di+0x399) [0x4a2179] [linux-finq:07753] [ 7] MycoalChemistryFoam4(_ZN4Foam15KinematicParcelINS_ 8particleEE4moveINS_14ReactingParcelINS_12ThermoPa rcelIS2_EEE12TrackingDataINS_23ReactingMultiphaseC loudINS_13ReactingCloudINS_11ThermoCloudINS_14Kine maticCloudINS_5CloudINS_24ReactingMultiphaseParcel IS7_EEEEEEEEEEEEEEEEbRT_d+0x3d0) [0x4d9b50] [linux-finq:07753] [ 8] MycoalChemistryFoam4(_ZN4Foam5CloudINS_24ReactingM ultiphaseParcelINS_14ReactingParcelINS_12ThermoPar celINS_15KinematicParcelINS_8particleEEEEEEEEEE4mo veINS8_12TrackingDataINS_23ReactingMultiphaseCloud INS_13ReactingCloudINS_11ThermoCloudINS_14Kinemati cCloudISA_EEEEEEEEEEEEvRT_d+0x365) [0x4df385] [linux-finq:07753] [ 9] MycoalChemistryFoam4(_ZN4Foam14KinematicCloudINS_5 CloudINS_24ReactingMultiphaseParcelINS_14ReactingP arcelINS_12ThermoParcelINS_15KinematicParcelINS_8p articleEEEEEEEEEEEE11evolveCloudINS9_12TrackingDat aINS_23ReactingMultiphaseCloudINS_13ReactingCloudI NS_11ThermoCloudISC_EEEEEEEEEEvRT_+0x276) [0x4e0396] [linux-finq:07753] [10] MycoalChemistryFoam4(_ZN4Foam14KinematicCloudINS_5 CloudINS_24ReactingMultiphaseParcelINS_14ReactingP arcelINS_12ThermoParcelINS_15KinematicParcelINS_8p articleEEEEEEEEEEEE5solveINS9_12TrackingDataINS_23 ReactingMultiphaseCloudINS_13ReactingCloudINS_11Th ermoCloudISC_EEEEEEEEEEvRT_+0x2bd) [0x4e06fd] [linux-finq:07753] [11] MycoalChemistryFoam4() [0x4428a5] [linux-finq:07753] [12] /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f75efdeabe5] [linux-finq:07753] [13] MycoalChemistryFoam4() [0x44ce2d] [linux-finq:07753] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 5 with PID 7753 on node linux-finq exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- TPT-Sim7@linux-finq:~/OpenFOAM/TPT-Sim7-2.2.2/run/Funkenberechnung1/0_Datumsordner/04_29_40mJ_0,4mmS4_constcp,vielStaub_fastReaction_ neuePyrolyse> mpirun -np 12 MycoalChemistryFoam4 -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2 Exec : MycoalChemistryFoam4 -parallel Date : Apr 30 2014 Time : 10:03:53 Host : "linux-finq" PID : 9957 Case : /home/TPT-Sim7/OpenFOAM/TPT-Sim7-2.2.2/run/Funkenberechnung1/0_Datumsordner/04_29_40mJ_0,4mmS4_constcp,vielStaub_fastReaction_ neuePyrolyse nProcs : 12 Slaves : 11 ( "linux-finq.9958" "linux-finq.9959" "linux-finq.9960" "linux-finq.9961" "linux-finq.9962" "linux-finq.9963" "linux-finq.9964" "linux-finq.9965" "linux-finq.9966" "linux-finq.9967" "linux-finq.9968" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0.0018 Reading g Creating combustion model Selecting combustion model infinitelyFastChemistry<psiThermoCombustion,gasHTh ermoPhysics> Selecting thermodynamics package { type hePsiThermo; mixture singleStepReactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader Fuel heat of combustion :44634083.44 stoichiometric air-fuel ratio :3.532718617 stoichiometric oxygen-fuel ratio :3.532718617 Maximum products mass concentrations: CO2: 0.6968982505 H2O: 0.3031017495 Combustion mode: explicit Creating component thermo properties: multi-component carrier - 7 species liquids - 1 components solids - 2 components Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Creating field dpdt Creating field kinetic energy K No finite volume options present Constructing coal cloud Constructing particle forces Selecting particle force sphereDrag Selecting particle force gravity Constructing cloud functions none Constructing particle injection models Creating injector: model1 Selecting injection model manualInjection Constructing 3-D injection Choosing nParticle to be a fixed value, massTotal variable now does not determine anything. Selecting distribution model RosinRammler Selecting dispersion model stochasticDispersionRAS Selecting patch interaction model standardWallInteraction Selecting surface film model none Selecting U integration scheme Euler Selecting heat transfer model RanzMarshall Selecting T integration scheme analytical Selecting composition model singleMixtureFraction --> FOAM Warning : From function phaseProperties::initialiseGlobalIds(...) in file phaseProperties/phaseProperties/phaseProperties.C at line 231 Assuming no mapping between solid and carrier species Selecting phase change model liquidEvaporation Participating liquid species: C16H34 Selecting devolatilisation model constantRateDevolatilisation Participating volatile species: CH4: particle mass fraction = 0 H2: particle mass fraction = 0 CO2: particle mass fraction = 0 Selecting surface reaction model COxidationKineticDiffusionLimitedRate C(s): particle mass fraction = 0.431848 Constructing limestone cloud employing parcel parcelTypeId of 2 Constructing particle forces Selecting particle force sphereDrag Selecting particle force gravity Constructing cloud functions none Constructing particle injection models Creating injector: model1 Selecting injection model manualInjection Constructing 3-D injection Selecting distribution model RosinRammler Selecting dispersion model stochasticDispersionRAS Selecting patch interaction model standardWallInteraction Selecting surface film model none Selecting U integration scheme Euler employing parcel parcelTypeId of 2 Selecting heat transfer model RanzMarshall Selecting T integration scheme analytical Selecting radiationModel none Courant Number mean: 0.0002599751084 max: 0.01511134008 PIMPLE: Operating solver in PISO mode Starting time loop Courant Number mean: 0.0002599751084 max: 0.01511134008 deltaT = 1.99920032e-08 Time = 0.00180002 Solving 3-D cloud coalCloud1 [3] #0 Foam::error:rintStack(Foam::Ostream&)[5] #0 [7] Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&) at ??:? [5] #1 Foam::sigFpe::sigHandler(int) at ??:? [7] #1 Foam::sigFpe::sigHandler(int) at ??:? [3] #1 Foam::sigFpe::sigHandler(int) at ??:? [5] #2 at ??:? [3] #2 at ??:? [7] #2 in "/lib64/libc.so.6" ... |
cloud, combustion, lagrange particle |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
