Sudden jumps in Courant in the middle of the simulation
Old   May 6, 2014, 07:43
Default Sudden jumps in Courant in the middle of the simulation
Pj.
Luca
Pj. is on a distinguished road
Hi everybody
I'm running a case with PIMPLE foam with the LES turbulence model.
The problem is that in the middle of the simulation, sudden jumps of several order of magnitude in Courant number appears. Then, strange fact number 2, the simulation converges again
This is the log from pimple foam with the iteration before and after the jump
Courant Number mean: 0.186631 max: 1.8437
Time = 5.575
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.00145738, Final residual = 6.64777e-09, No Iterations 6
DILUPBiCG:  Solving for Uy, Initial residual = 0.0604873, Final residual = 7.45712e-09, No Iterations 9
DILUPBiCG:  Solving for Uz, Initial residual = 0.0274295, Final residual = 8.88052e-09, No Iterations 8
DICPCG:  Solving for p, Initial residual = 0.141566, Final residual = 0.00692174, No Iterations 4
DICPCG:  Solving for p, Initial residual = 0.00791436, Final residual = 0.00037769, No Iterations 16
time step continuity errors : sum local = 7.22241e-08, global = -4.52688e-11, cumulative = -1.72326e-07
DICPCG:  Solving for p, Initial residual = 0.0161718, Final residual = 0.000756972, No Iterations 5
DICPCG:  Solving for p, Initial residual = 0.000876374, Final residual = 4.36954e-05, No Iterations 33
time step continuity errors : sum local = 8.49073e-09, global = -5.75816e-11, cumulative = -1.72383e-07
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 3.12497e-05, Final residual = 8.99954e-09, No Iterations 4
DILUPBiCG:  Solving for Uy, Initial residual = 0.000795909, Final residual = 1.19494e-09, No Iterations 8
DILUPBiCG:  Solving for Uz, Initial residual = 0.00029896, Final residual = 314.057, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 0.999977, Final residual = 0.0263806, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.0144061, Final residual = 0.000528999, No Iterations 8
time step continuity errors : sum local = 0.00441509, global = 9.945e-09, cumulative = -1.62438e-07
DICPCG:  Solving for p, Initial residual = 0.755181, Final residual = 0.0195148, No Iterations 3
DICPCG:  Solving for p, Initial residual = 0.0397071, Final residual = 9.8571e-07, No Iterations 250
time step continuity errors : sum local = 3.04181e-06, global = 1.62246e-07, cumulative = -1.91817e-10
ExecutionTime = 37649.6 s  ClockTime = 37697 s
Courant Number mean: 2.76008 max: 43683.4
Time = 5.576
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.289494, Final residual = 6.77395e-09, No Iterations 14
DILUPBiCG:  Solving for Uy, Initial residual = 0.305659, Final residual = 7.22824e-09, No Iterations 14
DILUPBiCG:  Solving for Uz, Initial residual = 0.316415, Final residual = 9.94743e-09, No Iterations 14
DICPCG:  Solving for p, Initial residual = 0.960833, Final residual = 0.0456337, No Iterations 8
DICPCG:  Solving for p, Initial residual = 0.0100212, Final residual = 0.000488464, No Iterations 49
time step continuity errors : sum local = 0.00244363, global = 1.20192e-05, cumulative = 1.2019e-05
DICPCG:  Solving for p, Initial residual = 0.0416985, Final residual = 0.00189429, No Iterations 10
DICPCG:  Solving for p, Initial residual = 0.00261552, Final residual = 0.000127246, No Iterations 92
time step continuity errors : sum local = 0.000612151, global = 5.09733e-05, cumulative = 6.29923e-05
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.242781, Final residual = 2.21545e-09, No Iterations 14
DILUPBiCG:  Solving for Uy, Initial residual = 0.247553, Final residual = 2.30642e-09, No Iterations 14
DILUPBiCG:  Solving for Uz, Initial residual = 0.276608, Final residual = 2.33162e-09, No Iterations 15
DICPCG:  Solving for p, Initial residual = 0.141775, Final residual = 0.0065789, No Iterations 5
DICPCG:  Solving for p, Initial residual = 0.00722017, Final residual = 0.000357133, No Iterations 66
time step continuity errors : sum local = 0.00165265, global = 0.000112039, cumulative = 0.000175032
DICPCG:  Solving for p, Initial residual = 0.0266265, Final residual = 0.00117149, No Iterations 6
DICPCG:  Solving for p, Initial residual = 0.00134573, Final residual = 9.69224e-07, No Iterations 505
time step continuity errors : sum local = 4.90204e-06, global = -6.92753e-09, cumulative = 0.000175025
ExecutionTime = 37659.3 s  ClockTime = 37707 s
as you can see the Uz could not be solved and the solver stopped after 1001 iterations.
I attached a plot of the MaxCo at each iteration on a semi logaritmic scale. As you can see, after the "jump" the Courant decrease and goes back to value around 1.7-2 as I want it. Then after a while a second jump happens.
This is the fvScheme
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,B)      Gauss limitedLinear 1;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div(B)          Gauss linear;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DBEff,B) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
and this the fvSolution
solvers
    p
        solver PCG;
        preconditioner DIC;
        tolerance 1e-06;
        relTol 0.05;
    pFinal
        solver PCG;
        preconditioner DIC;
        tolerance 1e-06;
        relTol 0;
    U
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-08;
        relTol           0;
    UFinal
        solver           PBiCG;
        tolerance        1e-08;
        relTol           0;
    nuTilda
        solver           PBiCG;
        tolerance        1e-07;
        relTol           0;
PIMPLE
    nCorrectors     2;
    nNonOrthogonalCorrectors 1;
    nOuterCorrectors 2;
relaxationFactors
    "U.*"               1;
    "nuTilda.*"         1;
What should i do? Thank you very much
Pj. is offline   Reply With Quote
Old   May 6, 2014, 12:23
Olivier
olivierG is on a distinguished road
hello,
add limiter to div(phi,U), like the limitedLiner you use after, or an other.
regards,
olivier
olivierG is offline   Reply With Quote
Simulation of suspension flow at sudden contractio QM Main CFD Forum 1 August 5, 2010 15:13
Overflow problem in steady simulation ReeKo CFX 11 October 8, 2008 17:57
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
pls help fluctuating residuals due to courant no sagar CFX 3 March 28, 2006 01:10
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
