probleme withe my new solver
Like Tree1Likes
  • 1 Post By Laisa
Old   May 22, 2014, 12:58
Default probleme withe my new solver
abdessamad
abdessamad is on a distinguished road
Hello everybody, I created my solver "myInterFoam" is based on a "interFoam" solver I added her temperature but when I want to run a simulation with him it does not work. knowing that all steps of implementation of new solver are are correct (no error when i tape wmake libso ... wmake):
when i want to use this new solver he give me this long message:
Duplicate entry Newtonian in runtime selection table viscosityModel
#0 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+ 0x25) [0x7fc3b62036f5]
#1 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/lib/libmyincompressibleTransportModels.so(+0x208ad) [0x7fc3b9d8c8ad]
#2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7fc3b9ff2306]
#3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7fc3b9ff23df]
#4 /lib64/ld-linux-x86-64.so.2(+0x16ea) [0x7fc3b9fe46ea]
Duplicate entry powerLaw in runtime selection table viscosityModel
#1 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/lib/libmyincompressibleTransportModels.so(+0x20a62) [0x7fc3b9d8ca62]
Duplicate entry CrossPowerLaw in runtime selection table viscosityModel
#1 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/lib/libmyincompressibleTransportModels.so(+0x20c0d) [0x7fc3b9d8cc0d]
Duplicate entry BirdCarreau in runtime selection table viscosityModel
#1 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/lib/libmyincompressibleTransportModels.so(+0x20dc2) [0x7fc3b9d8cdc2]
Duplicate entry HerschelBulkley in runtime selection table viscosityModel
#1 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/lib/libmyincompressibleTransportModels.so(+0x20f72) [0x7fc3b9d8cf72]
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : myInterFoam
Date : May 22 2014
Time : 17:44:38
Host : "abdessamad-Aspire-E1-571"
PID : 30749
Case : /home/abdessamad/Bureau/temp_drop
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading field T
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Calculating field g.h
No finite volume options present
time step continuity errors : sum local = 0.00496057, global = -0.00349517, cumulative = -0.00349517
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.0127256, No Iterations 4
time step continuity errors : sum local = 6.31265e-05, global = -1.5248e-05, cumulative = -0.00351041
Courant Number mean: 0.466106 max: 1.11756
Starting time loop
Courant Number mean: 0.416911 max: 0.999602
Interface Courant Number mean: 0.00480189 max: 0.869325
deltaT = 8.94454e-05
Time = 8.94454e-05
smoothSolver: Solving for alpha.water, Initial residual = 0.00483725, Final residual = 1.42992e-09, No Iterations 3
Phase-1 volume fraction = 0.071287 Min(alpha1) = 0 Max(alpha1) = 1.00003
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.071287 Min(alpha1) = -0.000942524 Max(alpha1) = 1.00003
smoothSolver: Solving for Ux, Initial residual = 0.192993, Final residual = 7.58645e-07, No Iterations 27
smoothSolver: Solving for Uy, Initial residual = 0.198859, Final residual = 8.19993e-07, No Iterations 24
GAMG: Solving for p_rgh, Initial residual = 0.210275, Final residual = 0.00105549, No Iterations 4
time step continuity errors : sum local = 5.40386e-05, global = -1.33186e-05, cumulative = -0.00352373
GAMG: Solving for p_rgh, Initial residual = 0.00420036, Final residual = 9.22092e-07, No Iterations 7
time step continuity errors : sum local = 1.11871e-06, global = 1.91106e-07, cumulative = -0.00352354
--> FOAM FATAL ERROR:
updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient.
From function fixedFluxPressureFvPatchScalarField::updateCoeffs( )
in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 151.
FOAM exiting
*** glibc detected *** myInterFoam: corrupted double-linked list: 0x0000000001f79d10 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x7eb96)[0x7fc3b4edcb96]
/lib/x86_64-linux-gnu/libc.so.6(+0x7ef00)[0x7fc3b4edcf00]
/lib/x86_64-linux-gnu/libc.so.6(+0x7fb89)[0x7fc3b4eddb89]
/lib/x86_64-linux-gnu/libc.so.6(+0x3b968)[0x7fc3b4e99968]
/lib/x86_64-linux-gnu/libc.so.6(+0x3b985)[0x7fc3b4e99985]
/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error4exitEi+0x163)[0x7fc3b5e4b203]
/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam35fixedFluxPressureFvPa tchScalarField12updateCoeffsEv+0xab)[0x7fc3b7ad47fb]
/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(+0xe82b73)[0x7fc3b81e5b73]
/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam2fv20gaussLaplacianSche meIddE23fvmLaplacianUncorrectedERKNS_14GeometricFi eldIdNS_13fvsPatchFieldENS_11surfaceMeshEEES8_RKNS 3_IdNS_12fvPatchFieldENS_7volMeshEEE+0x70)[0x7fc3b81fced0]
/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam2fv20gaussLaplacianSche meIddE12fvmLaplacianERKNS_14GeometricFieldIdNS_13f vsPatchFieldENS_11surfaceMeshEEERKNS3_IdNS_12fvPat chFieldENS_7volMeshEEE+0xa7)[0x7fc3b81ebbe7]
myInterFoam[0x47a2a7]
myInterFoam[0x441999]
myInterFoam[0x43177b]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x7fc3b4e7f76d]
myInterFoam[0x435d2d]
======= Memory map: ========
00400000-004b1000 r-xp 00000000 08:06 1078069 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/bin/myInterFoam
006b0000-006b3000 r--p 000b0000 08:06 1078069 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/bin/myInterFoam
006b3000-006b4000 rw-p 000b3000 08:06 1078069 /home/abdessamad/OpenFOAM/abdessamad-2.3.0/platforms/linux64GccDPOpt/bin/myInterFoam
01dd0000-032bc000 rw-p 00000000 00:00 0 [heap]
7fc3af83f000-7fc3afc45000 rw-p 00000000 00:00 0
7fc3afc45000-7fc3afc51000 r-xp 00000000 08:06 937343 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7fc3afc51000-7fc3afe50000 ---p 0000c000 08:06 937343 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7fc3afe50000-7fc3afe51000 r--p 0000b000 08:06 937343 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7fc3afe51000-7fc3afe52000 rw-p 0000c000 08:06 937343 /lib/x86_64-linux-gnu/libnss_files-2.15.so
7fc3afe52000-7fc3afe5c000 r-xp 00000000 08:06 937377 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7fc3afe5c000-7fc3b005c000 ---p 0000a000 08:06 937377 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7fc3b005c000-7fc3b005d000 r--p 0000a000 08:06 937377 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7fc3b005d000-7fc3b005e000 rw-p 0000b000 08:06 937377 /lib/x86_64-linux-gnu/libnss_nis-2.15.so
7fc3b005e000-7fc3b0066000 r-xp 00000000 08:06 937341 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7fc3b0066000-7fc3b0265000 ---p 00008000 08:06 937341 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7fc3b0265000-7fc3b0266000 r--p 00007000 08:06 937341 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7fc3b0266000-7fc3b0267000 rw-p 00008000 08:06 937341 /lib/x86_64-linux-gnu/libnss_compat-2.15.so
7fc3b0267000-7fc3b0289000 r-xp 00000000 08:06 442696 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so
7fc3b0289000-7fc3b0489000 ---p 00022000 08:06 442696 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so
7fc3b0489000-7fc3b048a000 r--p 00022000 08:06 442696 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so
7fc3b048a000-7fc3b048b000 rw-p 00023000 08:06 442696 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libthermophysicalFunctions.so
7fc3b048b000-7fc3b057a000 r-xp 00000000 08:06 442717 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidProperties.so
7fc3b057a000-7fc3b077a000 ---p 000ef000 08:06 442717 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidProperties.so
7fc3b077a000-7fc3b077e000 r--p 000ef000 08:06 442717 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidProperties.so
7fc3b077e000-7fc3b077f000 rw-p 000f3000 08:06 442717 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidProperties.so
7fc3b077f000-7fc3b078f000 r-xp 00000000 08:06 442742 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidProperties.so
7fc3b078f000-7fc3b098e000 ---p 00010000 08:06 442742 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidProperties.so
7fc3b098e000-7fc3b098f000 r--p 0000f000 08:06 442742 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidProperties.so
7fc3b098f000-7fc3b0990000 rw-p 00010000 08:06 442742 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidProperties.so
7fc3b0990000-7fc3b0997000 r-xp 00000000 08:06 442710 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidMixtureProperties.so
7fc3b0997000-7fc3b0b96000 ---p 00007000 08:06 442710 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidMixtureProperties.so
7fc3b0b96000-7fc3b0b97000 r--p 00006000 08:06 442710 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidMixtureProperties.so
7fc3b0b97000-7fc3b0b98000 rw-p 00007000 08:06 442710 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libliquidMixtureProperties.so
7fc3b0b98000-7fc3b0b9c000 r-xp 00000000 08:06 442740 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so
7fc3b0b9c000-7fc3b0d9b000 ---p 00004000 08:06 442740 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so
7fc3b0d9b000-7fc3b0d9c000 r--p 00003000 08:06 442740 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so
7fc3b0d9c000-7fc3b0d9d000 rw-p 00004000 08:06 442740 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidMixtureProperties.so
7fc3b0d9d000-7fc3b0da3000 r-xp 00000000 08:06 442683 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libSLGThermo.so
7fc3b0da3000-7fc3b0fa2000 ---p 00006000 08:06 442683 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libSLGThermo.so
7fc3b0fa2000-7fc3b0fa3000 r--p 00005000 08:06 442683 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libSLGThermo.so
7fc3b0fa3000-7fc3b0fa4000 rw-p 00006000 08:06 442683 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libSLGThermo.so
7fc3b0fa4000-7fc3b153b000 r-xp 00000000 08:06 442673 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so
7fc3b153b000-7fc3b173a000 ---p 00597000 08:06 442673 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so
7fc3b173a000-7fc3b175d000 r--p 00596000 08:06 442673 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so
7fc3b175d000-7fc3b1761000 rw-p 005b9000 08:06 442673 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so
7fc3b1761000-7fc3b1863000 r-xp 00000000 08:06 442724 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libradiationModels.so
7fc3b1863000-7fc3b1a63000 ---p 00102000 08:06 442724 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libradiationModels.so
7fc3b1a63000-7fc3b1a68000 r--p 00102000 08:06 442724 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libradiationModels.so
7fc3b1a68000-7fc3b1a6a000 rw-p 00107000 08:06 442724 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libradiationModels.so
7fc3b1a6a000-7fc3b1a95000 r-xp 00000000 08:06 442660 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidSpecie.so
7fc3b1a95000-7fc3b1c95000 ---p 0002b000 08:06 442660 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidSpecie.so
7fc3b1c95000-7fc3b1c96000 r--p 0002b000 08:06 442660 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidSpecie.so
7fc3b1c96000-7fc3b1c97000 rw-p 0002c000 08:06 442660 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidSpecie.so
7fc3b1c97000-7fc3b1fba000 r-xp 00000000 08:06 442765 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libspecie.so
7fc3b1fba000-7fc3b21b9000 ---p 00323000 08:06 442765 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libspecie.so
7fc3b21b9000-7fc3b21cb000 r--p 00322000 08:06 442765 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libspecie.so
7fc3b21cb000-7fc3b21cc000 rw-p 00334000 08:06 442765 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libspecie.so
7fc3b21cc000-7fc3b21ce000 rw-p 00000000 00:00 0
7fc3b21ce000-7fc3b237a000 r-xp 00000000 08:06 442704 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so
7fc3b237a000-7fc3b257a000 ---p 001ac000 08:06 442704 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so
7fc3b257a000-7fc3b2587000 r--p 001ac000 08:06 442704 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so
7fc3b2587000-7fc3b2589000 rw-p 001b9000 08:06 442704 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so
7fc3b2589000-7fc3b263e000 r-xp 00000000 08:06 442762 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidThermo.so
7fc3b263e000-7fc3b283e000 ---p 000b5000 08:06 442762 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidThermo.so
7fc3b283e000-7fc3b2842000 r--p 000b5000 08:06 442762 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidThermo.so
7fc3b2842000-7fc3b2843000 rw-p 000b9000 08:06 442762 /opt/openfoam230/platforms/linux64GccDPOpt/lib/libsolidThermo.so
7fc3b2843000-7fc3b285b000 r-xp 00000000 08:06 937378 /lib/x86_64-linux-gnu/libpthread-2.15.so
7fc3b285b000-7fc3b2a5a000 ---p 00018000 08:06 937378 /lib/x86_64-linux-gnu/libpthread-2.15.so
7fc3b2a5a000-7fc3b2a5b000 r--p 00017000 08:06 937378 /lib/x86_64-linux-gnu/libpthread-2.15.so
7fc3b2a5b000-7fc3b2a5c000 rw-p 00018000 08:06 937378 /lib/x86_64-linux-gnu/libpthread-2.15.so
7fc3b2a5c000-7fc3b2a60000 rw-p 00000000 00:00 0
7fc3b2a60000-7fc3b2a62000 r-xp 00000000 08:06 916616 /lib/x86_64-linux-gnu/libutil-2.15.so
7fc3b2a62000-7fc3b2c61000 ---p 00002000 08:06 916616 /lib/x86_64-linux-gnu/libutil-2.15.so
7fc3b2c61000-7fc3b2c62000 r--p 00001000 08:06 916616 /lib/x86_64-linux-gnu/libutil-2.15.so
7fc3b2c62000-7fc3b2c63000 rw-p 00002000 08:06 916616 /lib/x86_64-linux-gnu/libutil-2.15.so
7fc3b2c63000-7fc3b2c7a000 r-xp 00000000 08:06 937389 /lib/x86_64-linux-gnu/libnsl-2.15.so
7fc3b2c7a000-7fc3b2e79000 ---p 00017000 08:06 937389 /lib/x86_64-linux-gnu/libnsl-2.15.so
7fc3b2e79000-7fc3b2e7a000 r--p 00016000 08:06 937389 /lib/x86_64-linux-gnu/libnsl-2.15.so
7fc3b2e7a000-7fc3b2e7b000 rw-p 00017000 08:06 937389 /lib/x86_64-linux-gnu/libnsl-2.15.so
7fc3b2e7b000-7fc3b2e7d000 rw-p 00000000 00:00 0
7fc3b2e7d000-7fc3b2ecd000 r-xp 00000000 08:06 158819 /usr/lib/openmpi/lib/libopen-pal.so.0.0.0
7fc3b2ecd000-7fc3b30cd000 ---p 00050000 08:06 158819 /usr/lib/openmpi/lib/libopen-pal.so.0.0.0
7fc3b30cd000-7fc3b30ce000 r--p 00050000 08:06 158819 /usr/lib/openmpi/lib/libopen-pal.so.0.0.0
7fc3b30ce000-7fc3b30d0000 rw-p 00051000 08:06 158819 /usr/lib/openmpi/lib/libopen-pal.so.0.0.0
7fc3b30d0000-7fc3b30d4000 rw-p 00000000 00:00 0
7fc3b30d4000-7fc3b311d000 r-xp 00000000 08:06 158820 /usr/lib/openmpi/lib/libopen-rte.so.0.0.0
7fc3b311d000-7fc3b331d000 ---p 00049000 08:06 158820 /usr/lib/openmpi/lib/libopen-rte.so.0.0.0
7fc3b331d000-7fc3b331e000 r--p 00049000 08:06 158820 /usr/lib/openmpi/lib/libopen-rte.so.0.0.0
7fc3b331e000-7fc3b3320000 rw-p 0004a000 08:06 158820 /usr/lib/openmpi/lib/libopen-rte.so.0.0.0
7fc3b3320000-7fc3b3322000 rw-p 00000000 00:00 0
7fc3b3322000-7fc3b33b7000 r-xp 00000000 08:06 158815 /usr/lib/openmpi/lib/libmpi.so.0.0.2
7fc3b33b7000-7fc3b35b7000 ---p 00095000 08:06 158815 /usr/lib/openmpi/lib/libmpi.so.0.0.2
7fc3b35b7000-7fc3b35b8000 r--p 00095000 08:06 158815 /usr/lib/openmpi/lib/libmpi.so.0.0.2
7fc3b35b8000-7fc3b35c9000 rw-p 00096000 08:06 158815 /usr/lib/openmpi/lib/libmpi.so.0.0.2
7fc3b35c9000-7fc3b35d3000 rw-p 00000000 00:00 0
7fc3b35d3000-7fc3b35e9000 r-xp 00000000 08:06 916394 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7fc3b35e9000-7fc3b37e8000 ---p 00016000 08:06 916394 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
7fc3b37e8000-7fc3b37e9000 r--p 00015000 08:06 916394 /lib/x86_64-linux-gnu/libz.so.1.2.3.4Abandon (core dumped)
please someone give me a hint about this problem.Thank you
abdessamad is offline   Reply With Quote
Old   April 15, 2015, 19:37
Mike Foster
mfoster is on a distinguished road
Don't know if this response will still be valuable for you, but I had the same issue when working from a couple tutorials in order to include the energy equation into interFoam.
What happened for me is that I copied the $FOAM_SRC/transportModels/incompressible folder over to my local directory in order to change a few files. In the process, the viscosityModels folder comes with it. The duplicate entries error is due to the Make/options file in your new solver folder "seeing" both the new Models (Newtonian, powerLaw, etc.) you just copied over as well as the old ones in $FOAM_SRC.
Assuming you already added the following line in the Make/options file in your new solver folder...
EXE_INC = \
-I$(WM_PROJECT_USER_DIR)/src/transportModels/incompressible/lnInclude \
...then you just need to remove the following line:
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
Hope this helps!
Mike
mfoster is offline   Reply With Quote
Old   November 1, 2016, 13:19
Laisa is on a distinguished road
Hello Mike!
I did it and yet still gives the same error. You have idea of any other solution?
cdunn6754 likes this.
Laisa is offline   Reply With Quote
Old   May 26, 2017, 15:09
Clint
cdunn6754 is on a distinguished road
Originally Posted by Laisa View Post
Hello Mike!
Did you ever make any progress here? I have a similar situation, I got rid of the link to the original library but it still tells me I have duplicate entries.
cdunn6754 is offline   Reply With Quote
Old   June 2, 2017, 22:38
Mike Foster
What if you go to transportModels/incompressible/Make/files and remove all lines except for the location of your edited incompressibleTwoPhaseMixture?
You should have something like this:
myIncompressibleTwoPhaseMixture/myIncompressibleTwoPhaseMixture.C
LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleTransportModels
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 02:09
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
