May 24, 2014, 11:20 |
WallHeatFlux
Laurent DASTUGUE
Rep Power: 12 |
Hi everybody,
since last week i have a new job and i will use OpenFOAM daily. I am novice in the use of OF so i will ask you regularly some questions. Thanks for your help. Firstly, i had use openFOAM with the test-case "coaxial cylinder" and i don't obtain the same results than the guy who work in my position previously when i use the function WallHeatFlux. But i use his own files ! So my question is : Is there options on WallHeatFlux that i don't know ? If the answer is no, what could be the reason of this difference. For informations, i use OF 2.1.0 for the moment but i will upgrade it to the 2.3.0 version soon. Thanks you all. LaurentD |
May 25, 2014, 21:02 |
#2 | |
Andrew Somorjai
You can always try searching the threads first, I assume you didn't here's the search using google for the "WallHeatFlux". http://www.cfd-online.com/Forums/tags/wallheatflux.html You can also check the source if you haven't https://github.com/OpenFOAM/OpenFOAM...wallHeatFlux.C and this https://www.google.com/search?q=Wall...al&channel=rcs Hope it helps. As for parameters those are usually documented in the comments of the header file. |
May 26, 2014, 15:27 |
Thank you
Laurent DASTUGUE
Rep Power: 12 |
Thank you massive_turbulence,
i will look at the links you posted. |
results, wallheatflux |
wallHeatFlux and radiation | craig.tickle | OpenFOAM Post-Processing | 5 | December 2, 2018 08:00 |
problem with WallHeatFlux | Roman1 | OpenFOAM Running, Solving & CFD | 1 | January 24, 2014 10:31 |
wallHeatFlux utility in OpenFoam1.6 | maruthamuthu_venkatraman | OpenFOAM | 29 | October 3, 2011 10:43 |
wallHeatFlux BC not constant after restart | eelcovv | OpenFOAM Running, Solving & CFD | 26 | May 24, 2011 23:11 |
[swak4Foam] groovyBC + wallHeatFlux BC | prabhu | OpenFOAM Community Contributions | 1 | July 21, 2009 10:56 |
