How to delay releasing the water column in dam break case? |
June 2, 2014, 11:24 |
Pirlu Jing
Rep Power: 12 |
I have been using interFoam for a while and now i have a small question. I tried to find old posts, but don't know the relevant keywords to do searching. Here it is: Considering a simple dam break case, I need to release the water column after a period instead of from the beginning. How to implement? Thanks in advance for any suggestion, Jing |
June 3, 2014, 22:42 |
Pirlu Jing
Rep Power: 12 |
Specifically, can i set up a boundary condition that could be changed after a period (like remove a wall in DEM)?
June 4, 2014, 12:50 |
Marco A. Turcios
Rep Power: 28 |
The attachDetach mesh modifier will do what you want with the properly set trigger times.
June 4, 2014, 23:04 |
Pirlu Jing
Rep Power: 12 |
Thanks a lot, Marco.
I've found some of your helpful posts. I'll learn about it soon. Jing |
dambreak, interfoam, water column |
3D dam break flow problem | woochang | CFX | 1 | February 18, 2010 16:47 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
Dam break // wet bed | Mehdi BEN ELHADJ | Main CFD Forum | 4 | August 24, 2000 07:39 |
Dam break // wet bed | Mehdi BEN ELHADJ | Phoenics | 0 | August 23, 2000 12:47 |
