accelerate the convergence
Old   June 4, 2014, 15:38
Default accelerate the convergence
Olivia Nalen
entropie is on a distinguished road
Hello dear Foamers,
finally I've implemented in my solver for shape optimization the simpleFoam-equations for primal velocity U and pressure p (they are the same as equations in simpleFoam-solver, OF 2.3.0); and those for adjoint vel. Ua and pressure pa (they are the same as equations in adjointShapeOptimizationFoam, OF 2.3.0 but without alpha and lambda because I use a different gradient method for minimize cost function).
The first equations (U, p) converge after ~1500 iterations, and the adjoint equations (Ua,pa) need too much long:
Can I somehow accelerate this process? I thought, It should take about 5000-6000 iterations till the adjoint equations converge.
The BC's are ok, I've checked it already thousand times.
I thought, that maybe the mesh was too fine. At first, I have had 47000 cells. Now I have 16000 cells, but nevertheless the adjoint equations take too much time.
Have somebody any idea for this?
And thanks a lot in advance for every comment.
entropie is offline   Reply With Quote
Old   June 6, 2014, 02:54
T. Chourushi
Tushar@cfd is on a distinguished road
Please have a note that CFD simulation depends upon many factors.
One of the few factor is:
Try changing the under-relation factors to speed-up OpenFOAM solver.
relaxationFactors
fields
p 0.3; // try changing these values
equations
U 0.7; // try changing these values
k 0.7; // try changing these values
epsilon 0.7; // try changing these values
Apart from the under-relaxation factors, there are many other factors that you can play with. Please refer any of the CFD ebook for the same.
Best Luck!
Tushar@cfd is offline   Reply With Quote
Old   October 10, 2014, 18:58
Francisco Palacios
fpalacios is on a distinguished road
Maybe you can run the same simulation with SU2 (su2.stanford.edu)?
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Do you know of any tweaks of the solver parameters to accelerate solution convergence sek OpenFOAM Running, Solving & CFD 0 September 15, 2006 13:45
Accelerate convergence in coupled solver Balaji FLUENT 3 June 23, 2005 18:16
