Patch-> Cell-> Center - Face: Distance
Old   June 25, 2014, 10:34
Default Patch-> Cell-> Center - Face: Distance
Martin K
Martin_K_lalelu is on a distinguished road
Hi all,
I got stuck with a hopefully simple calculation. With a code sniplet out of this forum (dont remember where I found it) and some research, I try to calculate the distance of a cell center and face center, belonging to a patch cell called faceCelli.
forAll(myPatch, facei)
              label faceCelli = myPatch.faceCells()[facei];
              wallList.resize(wallList.size()+1);
              wallList[wallList.size()-1]=faceCelli;
              faceArea+=mesh.magSf()[faceCelli];
              cellMarker[faceCelli]=1.0;
              C[faceCelli]=mesh.C()[faceCelli];
              Cf[faceCelli]=mesh.Cf()[facei];
              cellFaceDistanceVector[faceCelli] =C[faceCelli] - Cf[facei];  //Cf[faceCelli] wont work either
              cellFaceDistance[faceCelli]= mag(cellFaceDistanceVector[faceCelli]);
The distance between cell center and cell face center becomes way too large.
As I can see in my timeName.C and .Cf, they are both calculated on the correct cell ID. So why wont I get the correct distance?
Best regards
Martin
Martin_K_lalelu is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
