July 3, 2014, 09:47 |
reactingFoam for supersonic flow?
Rep Power: 12 |
I like to use reactingFoam to simulate an ALD reactor. Since I reach velocities up to 450 m/s I like to know if reactingFoam can be used for supersonic flow. And if not, how can I implement such a capability? Where do I have to look in the source code to find out if a solver is suited for supersonic flow? Would rhoReactingFoam be a better choice? Thanks in advance for any info! hester |
July 4, 2014, 10:51 |
Bobby
Rep Power: 15 |
Greetings Hester
rhoReactingFoam is much better for fully compressible flows. Cause it solves the rho equation every time step. Although reactingFoam uses compressible schemes due to not solving rho equation, is not suitable for supersonic flows. Although for non-reacting cases you can use sonicfoam too. Regards Bobi |
July 6, 2014, 05:15 |
Rep Power: 12 |
Hello Bobi,
thank you for your fast answer. Since I have a reacting flow I will try rhoReactingFoam. It sounds very promising. regards hester |
December 18, 2014, 12:34 |
Jacopo
Rep Power: 13 |
Hi Hester - Did you managed to successfully use rhoReactingFoam for supersonic flows? I am dealing with the similar problem and would like to know the right track to follow.
December 19, 2014, 07:24 |
Rep Power: 12 |
Hello yagb,
I wasn't able to realise my simulation. My simulation looked fine at the beginning but got unstable due to supersonic flow at some point. There is probably a solution to it but I could not figure it out. Anyway, I think rhoReactingFoam is the appropriate solver for such problems. I hope you are more successful! regards hester |
December 27, 2014, 13:45 |
Dmitry
Rep Power: 11 |
Hello Hester,
I would like to suggest to try my solver edcPisoFoam =) which is based on rhoReactingFoam and incorporates the Eddy Dissipation Concept with a detailed chemistry approach for the turbulence-chemistry interaction. I have finished my PhD related to OpenFOAM and turbulent combustion modeling with OpenFOAM this year using this solver, so it has good validation and references =) You can download it for free from: http://www.edcpisofoam.decgroup.org/ Thx, Dmitry |
February 8, 2015, 09:38 |
Rep Power: 12 |
Hello Dmitry,
I’m currently not working on this project. If I find time I will continue and also look at your solver. Thanks for the tip! regards hester |
May 11, 2015, 15:13 |
#8 | |
Howar
Rep Power: 11 |
HTML Code:
[HTML][HTML][HTML] Quote:
Hi, friend, I'm interested in this solver. I try to install your edcPisoFoam, but always have problem(as the pictures in attachment), could you give some suggestion? Thank you |
June 6, 2016, 08:37 |
#9 | |
Mukesh Adlak
Rep Power: 9 |
Hi, I am working on mixing of H2 & air at supersonic speed. I tried rhoreactingfoam but at high speed it has stopped after some iteration can u send me ur files at mukesh22adlak@gmail.com I am also trying for doing the same with sonicfoam but not successful yet. |
June 6, 2016, 12:47 |
#10 |
Rep Power: 12 |
Hello Mukesh,
I was not able to produce a working case, so rhoReactingFoam should probably not be used for supersonic flows - see comment from babakflame above. SonicFoam might work, but I have no experience with this solver. I wish you good luck! |
June 6, 2016, 15:14 |
#11 | |
Mukesh Adlak
Rep Power: 9 |
August 4, 2016, 07:23 |
#12 | |
Mukesh Adlak
Rep Power: 9 |
rhoReactingFoam is good for compressible transonic/subsonic flows. But It is not working for supersonic flows. Can u tell me how to modify it for supersonic flows. |
September 22, 2021, 03:25 |
#13 |
Hosam Alrefaie
Rep Power: 4 |
Hi
it is not clear how to download or implement edcPisoFoam. I am trying to use it because I heard that it has WSGGM model in it. What I want is to get WSGGM radiation submodel. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 01:22 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
