chtMultiRegionFoam internal boundarys
Old   August 14, 2014, 12:13
Post chtMultiRegionFoam internal boundarys
Jordan
Jordan. is on a distinguished road
After extensive research into chtMultiRegionFoam I am yet to get temperature to cross a boundary between solids or fluids. I have looked at all of the cfd forum posts about it and looked extensively at the tutorials. I have attached my folders and a screenshot of paraveiw showing me the solution, which does not change with time (for a minuet). All I want to do is get tempreture flow from a solid/fluid to a solid/fluid, my geometry is essentially a tower block starting with 2 solid sections then a fluid section then back to a solid section numbers form 1 to 4. This is exactly what I have done after setting up the folders appropriately:
fluentMeshToFoam constant/polyFoam/thermo9FL.msh -writeSets
setsToZones -noFlipMap
splitMeshRegions -cellZones -overwrite
Then delete all 0/region/files that are not applicable to solids/fluids.
ChangeConditions (a bash file I wrote to run changeDictionary for all regions in turn)
Then I renamed all *Zones by adding .bak
StitchMeshes (another bash file that runs stitchMesh -overwrite -perfect on all internal walls)
Then remove the new cellZones and remove the .bak from the old one
Then delete all boundary's with 0 in nFaces in constant/polyMesh/boundarys
checkMesh (says its ok)
Then change all boundary's in constant/region/polyMesh/boundarys to mappedwall for the internal walls to match the 0 condition of compressible::turbulentTemperatureCoupledBaffleMix ed that is set up.
Then move meshPhi form the 0 folder to 0/topRegionInTheFolder (otherwise I get an error)
chtMultiRegionFoam
paraFoam
----------end
Additionally: why does there need to be a small velocity passing though a fluid to make the fluid allow heat to flow from one of its boundary's e.g. use 'fixedValue' and set a wall surrounding a fluid to 500K, it only heats up the fluid if there is a small velocity running though it. I have the same problem with a solid however have no solution to make the heat move throughout it.
I am currently using OpenFOAM V2.1
NOTE: I had to upload the constant folder separately and had to delete some of its files so it would upload (eg faces, the mesh, sets, ...)
Jordan. is offline   Reply With Quote
baffle interface, chtmultiregionfoam, fluentmeshtofoam, stitchmesh, temperature bc
Error in thermophysical properties (chtMultiRegionFoam) mukut OpenFOAM Pre-Processing 28 November 23, 2021 06:34
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 17:08
Create an internal face aylalisa OpenFOAM Pre-Processing 1 June 19, 2013 12:02
[Commercial meshers] Internal boundary problem stefanke OpenFOAM Meshing & Mesh Conversion 2 May 24, 2011 02:21
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
