simultaneously solve number of diffusion equations
Like Tree1Likes
  • 1 Post By Henning86
Old   August 26, 2014, 08:21
Default simultaneously solve number of diffusion equations
Shakil Masum
Shakil Masum is on a distinguished road
I want to solve these equations using OpenFOAM. The diffusion equations are:
dC0/dt = D1 d2/dx2 C0
dC1/dt = D1 d2/dx2 C1 + D2 d2/dx2 C0 (please check the attachment, I have typed them properly in the attachment).
I can solve the equations using Laplacian Foam individually. But, I want to solve both equations simultaneously, I mean in every time steps. The problem is the second equation needs the value of C0 (from first equation) in every time step. What changes are required in laplacianFoam.C and also in the '0', 'constant' and 'system' folders? It will be much appreciated.
thanks
shakil
Shakil Masum is offline   Reply With Quote
Old   August 27, 2014, 06:04
Alex
al_pr is on a distinguished road
You could try to define your concentrations C1 and C0 as a vector and solve one PDE system instead of two separate PDEs.
That means a volVectorfield instead of a volScalarField in your createFields.H.
Best regards,
Al
al_pr is offline   Reply With Quote
Old   August 27, 2014, 08:59
Shakil Masum
Thanks for your reply al_pr.
But I am worried that you cannot consider C0 and C1 as vectors. These are concentrations which are scalars and direction independent.
Old   August 27, 2014, 09:45
Henning86 is on a distinguished road
you could formulate it is explicit.
Equations.
in OpenFOAM:
C0Eqn
fvm::ddt(C0) == fvm::laplacian(D1,C0)
C1Eqn
fvm::ddt(C1) == fvm::laplacian(D1,C1) +fvc::laplacian(D2,C0)
shovon99 likes this.
Henning86 is offline   Reply With Quote
Old   August 27, 2014, 13:07
Shakil Masum
Dear Henning86,
Thanks a lot. I think this is a brilliant idea.
I believe it will also solve the the problem of solving two equations simultaneously in every time step with the updated value of C0 to calculate C1. Am I right to interpret in this way?
Thanks again
Old   August 29, 2014, 05:02
yes you are right.
As C1Eqn has an explicit term you are limited by the time step.
diffusion, laplacian
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries vkrastev OpenFOAM Pre-Processing 7 June 2, 2016 15:50
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
modify fvMatrix / coupled equations / higher order diffusion Jinming OpenFOAM Programming & Development 0 May 7, 2011 06:20
