cyclic boundary conditions for particles
Like Tree2Likes
  • 1 Post By randolph
  • 1 Post By JulioPieri
Old   September 10, 2014, 18:26
Post cyclic boundary conditions for particles
sophie_l is on a distinguished road
I'm using MPPICFoam (v2.3.0). A simple test case in a column has been set up. Particles are sitting on the bed initially. I want to set the left and right patch to be cyclic for the particles, so that particles that escape from the left patch will enter through the right patch again. Therefore, equilibrium status can be achieved using less computational resources. I tried
patchInteractionModel multiInteraction;
multiInteractionCoeffs
model1
patchInteractionModel coincidentBaffleInteraction;
but 'coincidentBaffleInteraction' is not recognised. I guess I have to dig out the code for coincidentBaffleInteraction and compile it. However I'm not sure whether this can help with the periodic boundary condition for particles.
Then I simply tried out using 'escape' for the left patch and right patch, both of which are of the patchType cyclic and correspond to each other. But as expected, particles just escape and cannot enter into the domain again. Just wondering how can I specify periodic boundary conditions for particles?
thanks,
Sophie
sophie_l is offline   Reply With Quote
Old   February 11, 2015, 15:16
Nadish Saini
90nash is on a distinguished road
Hello Sophie,
I am currently working on developing my own code for particle interaction and i need to employ periodic BC on left and right faces. I am however working on a structured grid solver. In Control volume approach you usually generate ghost cells around the original grid wherein you can apply the BC's. So for example particles exit from right most cell of the original grid to the ghost cell, you then specify that the particle coordinates are changed so that it 'appears' in the leftmost grid cell at the corresponding coordinate. I am not an expert on unstructured grids but i am sure the implementation would be similar in principle.
I am curious if OF offers such a BC for particles. Please share if you have found a solution.
Thanks & Regards.
90nash is offline   Reply With Quote
Old   March 1, 2016, 12:32
C-L
Charlie Lloyd
C-L is on a distinguished road
Sorry to restart this thread but I am trying to tackle a similar problem using DPMFoam and require cyclic boundary conditions for the particle phase. Did either of you manage to find a solution to this problem?
Thanks,
Charlie
C-L is offline   Reply With Quote
Old   March 28, 2016, 11:19
Jesus Ramirez
jarpve is on a distinguished road
Hello all,
I am also trying to figure out how to implement cyclic BC's for the particles. Have you already a solution or any idea?.
Thank you.
jarpve is offline   Reply With Quote
Old   March 30, 2016, 06:05
C-L
Charlie Lloyd
Originally Posted by jarpve View Post
Hello all,
Thank you.
Hi jarpve,
I havn't validated the model yet but it is possible to apply cyclic BCs if you change the 'patchInteractionModel' to 'standardWallInteraction' and just specify the interaction coefficients for the wall. Although there is no fvOptions term in the velocity equation in DPMFoam so you can't specify a bulk flow velocity. To stop the flow slowing down over time you have to add fvOptions to DPMFoam. You can look at the standard pimpleFoam solver to see how this is done.
Hope that helps!
Old   April 1, 2016, 07:28
Jesus Ramirez
Originally Posted by C-L View Post
Hi jarpve,
Hope that helps!
Hello Charlie,
Thank you for your answer. I am going to do it and I will tell you how it was.
Old   May 18, 2016, 08:36
Default Particles are inserted in DPMFoam cyclic BCs
Muhammad Usman
msman is on a distinguished road
Hello everyone,
I have to add fvOptions to DPMFoam eventhough no particle has been inserted to DPMFoam when I applied cyclic BCs.
Thank you.
msman is offline   Reply With Quote
Old   September 11, 2016, 03:58
Default particle stress model
Saeed
hrhm_04 is on a distinguished road
Hello dears,
Can anybody explain the parameters "Ps" and "beta" in Harris-Crighton model for particle stress?? I couldn't find any refrences.
what are the values for different particles??
Thank you
hrhm_04 is offline   Reply With Quote
Old   November 10, 2017, 16:08
Joaquín Neira
cojua8 is on a distinguished road
Has anyone found a solution to this?
I have a test case where the left and right patch have different pressures so there is flow.
My question is: how can I keep this condition but also let those patches be cyclic for the particles?
cojua8 is offline   Reply With Quote
Old   January 24, 2018, 12:56
Dominik Münch
DominikM is on a distinguished road
Did you make the coincidentBaffleInteraction work or did you find another way to assign cyclic boundary conditions for a particle simulation? Unfortunately I also haven't made it work for me yet although spending a lot of time on it.
DominikM is offline   Reply With Quote
Old   October 13, 2020, 09:44
Reviewer #2
randolph is on a distinguished road
For people who run into this problem,
In order to get the cyclic for the particle follows:
1. give cyclic boundary condition in for the flow (i.e., cyclic in blockMesh and flow solver)
2. DO NOT specify the boundary condition in the "localInteractionCoeffs"
Thanks,
Rdf
JulioPieri likes this.
randolph is offline   Reply With Quote
Old   September 9, 2021, 17:18
Julio Pieri
JulioPieri is on a distinguished road
Thanks,
Rdf
To complement this, you can specify "type none;" to the patch in "localInteractionCoeffs" if OF complains you haven't specified an interaction for a patch.
lxufeishi likes this.
JulioPieri is offline   Reply With Quote
cyclic bc, particles
Cyclic boundary conditions - not parallel patches Villo OpenFOAM Running, Solving & CFD 3 July 14, 2014 22:50
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
snnappyHexMesh with cyclic boundary conditions longamon OpenFOAM 2 May 9, 2011 12:28
periodic and cyclic boundary conditions Hadi Main CFD Forum 2 June 29, 2007 07:19
