force coefficient's amplitude
Old   September 22, 2014, 04:59
Default force coefficient's amplitude
Konstantine is on a distinguished road
hi
I am using the icofoam on a Re=100 around a cylinder flow. the frequency of the force coefficients is correct but i am getting wrong amplitude, meaning the oscillation happens around value much higher than it should be according to papers and books
it should be oscillating around 1.44 but it oscillates around 3. any ideas with this happens. I have checked the coefficient formula it is the usual one so no problem there.
Konstantine is offline   Reply With Quote
Old   March 7, 2015, 14:23
Pruthvi
pruthvi1991 is on a distinguished road
Whats the depth of your domain? I'm referring to the Z-direction. Value of Aref should be chordlength*domaindepth
pruthvi1991 is offline   Reply With Quote
Old   March 9, 2015, 07:16
thank you for your reply, the truth is that the depth is very small comparing to the diameter of the cylinder like 1/10 of the dimaeter and this possibly could explain the differnece in the forces, Aref should be the actual area against the flow which is the depth times the diameter, probably i have to change the coefficient calculations which i have done but then it was very small. any way good tip but i need to rerun which takes time
Old   March 9, 2015, 11:49
Default execFlowFunctionObjects
Pruthvi
Hello Konstantine,
You do not need to rerun the case. Just use "execFlowFunctionObjects". It is a post processing tool. It will integrate the pressure over the surface. Type "execFlowFunctionObjects" in the directory which has all the time steps.
Old   March 10, 2015, 06:00
i probably need to transform the forces results by dividing with the proper surface rather than Aref=1 which is commonly used. i guess the routine you propose is for the open-foam? i made some tries with the open foam managed to set up something 2d, but the forces were wrong in everything frequency and amplitude. i am running flow around circular cylinder 3d code non commercial or commonly used code. anyway currently i cannot run anything so when i can i will update thread if something did change to the better.
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Sectional force coefficients tfuwa OpenFOAM Post-Processing 1 June 27, 2013 06:49
[OpenFOAM] spatial distribution of force coefficients in paraview&openfoam kkpal ParaView 1 April 21, 2013 07:15
[General] spatial distribution of force coefficients in paraview&openfoam kkpal ParaView 0 April 17, 2013 04:43
Force can not converge colopolo CFX 13 October 4, 2011 22:03
