What does this error when use solver chtMultiRegionFoam mean
Old   October 2, 2014, 05:09
Default What does this error when use solver chtMultiRegionFoam mean
sajad
sajad6 is on a distinguished road
When I use openfoam turorials multiRegionHeater when I write blockMesh in terminal there isnt any problem but when I write chtMultiRegionFoam terminal write this :
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-0bc225064152
Exec : chtMultiRegionFoam
Date : Oct 02 2014
Time : 12:04:55
Host : "sajad-pc"
PID : 1938
Case : /home/sajad/Desktop/multiRegionHeater
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region bottomAir for time = 0
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "bottomAir/polyMesh" in times 0 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
in file db/Time/findInstance.C at line 188.
FOAM exiting
what's the problem?is anybody now ? I exactly copy the openfoam tutorial and use chtMultiRegionFoam solver.why it write fatal error?
sajad6 is offline   Reply With Quote
Old   October 2, 2014, 05:18
Laurent Fitschy
GDTech is on a distinguished road
That error means your mesh has not been built correctly.
Running blockMesh is not enough to create a multi region case for chtMultiRegionFoam because mesh has to be split into regions.
Have a look at Allrun script in the tutorial directory and execute it.
Regards.
GDTech is offline   Reply With Quote
Old   October 2, 2014, 16:03
sajad
Originally Posted by GDTech View Post
Regards.
tnx for your reply.
do you mean that I should change openfoam tutorial multiRegionHeater to see this solver how work?multiRegionHeater isn't complete?
if multiRegionHeater is incomplete do you have any complete tutorial in order to see chtMultiRegionFoam how work?
Old   October 3, 2014, 02:28
Laurent Fitschy
No, I said you have to use Allrun script :
Regards.
Old   October 3, 2014, 13:27
sajad
tnx for your answer.
I execute ./Allrun and terminal write this:
sajad@sajad-pc:~/Desktop/multiRegionHeater$ ./Allrun
blockMesh already run on /home/sajad/Desktop/multiRegionHeater: remove log file to re-run
Running topoSet on /home/sajad/Desktop/multiRegionHeater
splitMeshRegions already run on /home/sajad/Desktop/multiRegionHeater: remove log file to re-run
Running chtMultiRegionSimpleFoam on /home/sajad/Desktop/multiRegionHeater
creating files for paraview post-processing
created 'multiRegionHeater.blockMesh'
created 'multiRegionHeater.OpenFOAM'
created 'multiRegionHeater{bottomAir}.OpenFOAM'
created 'multiRegionHeater{heater}.OpenFOAM'
created 'multiRegionHeater{leftSolid}.OpenFOAM'
created 'multiRegionHeater{rightSolid}.OpenFOAM'
created 'multiRegionHeater{surrondingSolid}.OpenFOAM'
created 'multiRegionHeater{topAir}.OpenFOAM'
creating files for residual
./Allrun: 58: foamLog: Permission denied
why at the end it write Permission denied?
Old   October 3, 2014, 14:18
Alex
zfaraday will become famous soon enough
Try first to run ./Allclean.
If you don't have permissions type in the temrinal
chmod +x <name of the document>
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   October 3, 2014, 15:15
sajad
Regards,
Alex
tnx for your replying.
I don't use chmod until now.can you tell me how can I use this command for my purpose ? what is +x in this command ? what document I should write to permit me solve the problem ?
Old   October 6, 2014, 07:38
Alex
What you are requesting you can easily find it out by yourself by typing in the terminal:
chmod --help
Regards,
Alex
EMMS drag model UDF NAD Fluent UDF and Scheme Programming 26 November 19, 2017 07:49
Can't get data from OpenFoam to external solver using externalCoupled perry OpenFOAM Running, Solving & CFD 4 May 26, 2014 08:09
Using a Different Thermodynamics Package with the chtMultiRegionFoam Solver m.nichols19 OpenFOAM 7 March 17, 2011 16:26
Creating a new solver from chtMultiRegionFoam David_010 OpenFOAM Programming & Development 0 April 20, 2010 11:36
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
