request for surfaceScalarField nHatf error with twoMixingLiquidsMixingFoam |
June 15, 2022, 20:46 |
Miriam
Hello all,
I am getting the following error with the twoLiquidMixingFoam solver, I am modelling a pipe vertical flow and it has an injection of another liquid in the middle of the pipe. I have no idea where to look for the error... it runs with interfoam but not with this solver. Any suggestions? --> FOAM FATAL ERROR: request for surfaceScalarField nHatf from objectRegistry region0 failed available objects of type surfaceScalarField are 4 ( rhoPhi ghf rhoPhiSum phi ) From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>] in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 211. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvsPatchField, Foam::surfaceMesh> const>(Foam::word const&) const at ??:? #3 Foam::interfaceCompressionNew::interpolate(Foam::G eometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #4 Foam::fv::gaussConvectionScheme<double>::flux(Foam ::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/twoLiquidMixingFoam" #6 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/twoLiquidMixingFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/twoLiquidMixingFoam" Aborted (core dumped) |
March 6, 2024, 11:06 |
LeiXu
hello,
Have you solved this problem? I also met it when I want to use the twoLiquidMixingFoam |
September 12, 2024, 12:34 |
I've also encountered this issue while using incompressibleMultiphaseVoF (OF Version 12). I tested a bit and it seems the issue lies in the divSchemes you choose. For my div(phi, alpha) I tried "Gauss interfaceCompression vanLeer 1" which produced the same error. Using standard vanLeer for my discretization did the trick. Not sure why interfaceCompression with vanLeer won't work here. |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 11:31 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
Problem with paraFoam | ata | OpenFOAM | 14 | November 30, 2009 05:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
[OpenFOAM] Xwindows crash with paraview save | srinath | ParaView | 1 | October 15, 2008 10:37 |
