interFoam with moving reference frame
Old   November 4, 2014, 02:41
Default interFoam with moving reference frame
Martin K
Martin_K_lalelu is on a distinguished road
for calculating a falling sphere in a moving reference frame with interFoam, I added a momentum source in UEqn as seen in http://powerlab.fsb.hr/ped/kturbo/Op...chePhD2002.pdf
The term I added in the LHS of UEqn looks like
+ accelerationSphere*rho
It is mentioned, that a similar work around should be done with the transport equation of the volume fraction, could anyone give me a hint on how to manage this?
Is the frame acceleration taken into account, when the alphaEqn is solved or do I have to adjust it manually?
Do I have do change phi to make it relative, like MRFinterFoam does?
regards
Martin
Edit: Additional question, how could I consider the frame Velocity and Position in to the alphaEqn?
Martin_K_lalelu is offline   Reply With Quote
interfoam moving frame
Question about N-S eqs. in body fixed noninertial reference frame doctorWho Main CFD Forum 0 July 12, 2011 18:07
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
Unsteady moving reference frame impecca OpenFOAM Running, Solving & CFD 0 November 14, 2010 14:41
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
