chtmultiregionsimplefoam: different pressure values in openFoam and Fluent
Prev Previous Post   Next Post Next
Old   November 7, 2014, 03:35
Default chtmultiregionsimplefoam: different pressure values in openFoam and Fluent
Paritosh Vasava
vasava will become famous soon enough
I have made a fluid a fluid heating case in openFoam and Fluent using same boundary conditions. All the results including velocity and heat distribution match nicely. However the highers pressure value in fluent is about 200000 Pascals and in openFoam it is as high as 9^17 Pa.
Sorry but I can not post any other results or pictures here.
But It would be a great help if someone can explain how pressure is calculated in chtmultiregionsimplefoam solver. Should I multiply or divide by some other parameter to make the range of the pressure equivalent to that of Fluent?
Here is my inlet and outlet velocity boundary conditions:
    inlet
        type            zeroGradient;
    outlet
        type            flowRateInletVelocity;
        massFlowRate    constant -0.742;//(kg/s) Target mass flow through outlet
        value           uniform (0 0 0);
I have tried following for p_rgh:
    inlet
        type            fixedValue;
        value           uniform 0;//$internalField;
    outlet
        type            zeroGradient;
And following for p:
    inlet
        type            calculated;
    outlet
        type            calculated;
Also changing uniform 0; to $internalField; does not help.
vasava is offline   Reply With Quote
Reference pressure in OpenFOAM P.Satish OpenFOAM Running, Solving & CFD 7 December 21, 2017 12:01
pressure and velocity in OpenFoam is smaller than Fluent mechy OpenFOAM 4 September 18, 2013 16:19
How to view mean pressure fields in Fluent after importing data from openFOAM !!! Alhasan FLUENT 0 July 23, 2013 12:58
Operating Pressure in Fluent how to set in OpenFoam alimansouri OpenFOAM Running, Solving & CFD 3 September 3, 2010 03:38
Matching Velocity and Pressure fields Fluent OpenFoam alimansouri OpenFOAM Running, Solving & CFD 0 January 13, 2009 17:51
