Bugs with caveatingFoam tutorial
Old   November 12, 2014, 01:52
Default Bugs with caveatingFoam tutorial
BO WANG
wang219910611 is on a distinguished road
Hi Everyone,
I am a newbee with Openfoam and I am currently trying to get familiar with it with its tutorial. (Many bugs happened by the way..)
Something strange happened. I have run sprayFoam and everything is fine. But when I run ./Allrun in the cavitatingFoam case, the log file showed errors as following:
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:?
#9 Foam::incompressible::RASModels::kOmegaSST::correc t() at ??:?
at ??:?
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
at ??:?
Floating point exception (core dumped)
Can anyone offer any advice about this? Your help will be appreciated. : )
wang219910611 is offline   Reply With Quote
Old   November 12, 2014, 04:02
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I guess you're talking about tutorials/multiphase/cavitatingFoam/ras/throttle case (as there are several cases). The case is quite strange starting with 5-element vector for dimensions (now it should be 7-element vector or symbolic expression, so I guess this case was copied from older versions of OpenFOAM without verification), ending with this sigFpe.
I was able to execute the case (though don't know whether results are meaningful or not) if I change linear system solver for U/k/omega from smoothSolver to PBiCG, i.e. I change fvSolution to:
    "(U|k|omega)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-8;
        relTol          0.1;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-08;
        relTol          0.1;
    "(U|k|omega)Final"
        $U;
        relTol          0;
        tolerance       1e-08;
        relTol          0;
alexeym is offline   Reply With Quote
Old   November 18, 2014, 03:24
Smile
BO WANG
Originally Posted by alexeym View Post
    "(U|k|omega)"
        solver          PBiCG;
        tolerance       1e-8;
        relTol          0.1;
        tolerance       1e-08;
        relTol          0.1;
    "(U|k|omega)Final"
        $U;
        relTol          0;
        tolerance       1e-08;
        relTol          0;
Hi Alexeym,
Thanks for the kind reply. I have followed your suggestion and the case runs out well. About the dimensions, I have checked through the source file, and found out several vectors in 5-element, and the rest in 7-element.
However, the result seemed a bit strange to me. The nozzle flow is super-cavitating all the way to the end. I am wonder if this is the right calculation.
Regards
Bo
Old   November 18, 2014, 03:58
Alexey Matveichev
Well, there are two ways to check correctness of the calculations:
1. Find a published paper with results and try to reproduce them
2. Find author of the tutorial case and ask him about results
As I'm neither a specialist in cavitation, nor a user of cavitatingFoam, I can only suggest technical things to make the case running.
Old   November 18, 2014, 04:02
Thumbs up
BO WANG
I think I can try to compare the results with some papers. Thanks for the quick reply and suggestion. : D
cavitatingfoam
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 16:01
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
