November 19, 2014, 07:52 |
discretization error and order of accuracy
Rep Power: 12 |
Hello Foamers,
I'm running a simple steady-state incompressible 2D laminar test-case of a divergent-convergent channel on OF 2.3.0. In order to estimate the discretization error I performed a mesh study with the "Richardson-Extrapolation" (See e.g. "Computational Methods for Fluid Dynamics" by Ferziger and Peric). The three hex-meshes were refined in x- and y-direction by a factor of r=2. The numerical schemes are of second order Code:
ddtSchemes { default steadyState; } gradSchemes { default leastSquares; } divSchemes { default none; div(phi,U) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } Code:
p = log[(Phi_2h - Phi_4h)/(Phi_h - Phi_2h)] / log r For several sample-points along the flow-direction, when using the x-velocity-component, I get orders varying from 1.2 to 3.3. Where do these differences originate from? Are these indicators of local mesh quality and fineness? So if the estimated order is low, the mesh should be refined in this area? Also for some sample points, the pressure does not increase monotonically, but decreases from the middle to the fine mesh. I'll check the values and samples again, but does anyone have an explanation for that? In order to estimate the discretization error afterwards, the following equation is used: Code:
epsilon = (Phi_h - Phi_2h)/(r^p - 1) Philip |
