Using RAS turbulence modelling in multiphaseEulerFoam (OF 2.1.1)
Old   November 26, 2014, 09:45
Default Using RAS turbulence modelling in multiphaseEulerFoam (OF 2.1.1)
Anurag
anuragm is on a distinguished road
Hello everyone!
From what I've gathered, multiphaseEulerFoam is a LES-based solver. Since I intend to include population balance equations to this solver, I would like to use a less computationally intensive turbulence modelling (RAS). I'm trying to modify the solver so that the turbulence model may be switched from the case directory using turbulenceProperties. I made the following changes:
1. In the file multiphaseEulerFoam.C
#include "LESModel.H"
to
#include "turbulenceModel.H"
and,
sgsModel->correct();
to
turbulence->correct();
2. In the file createFields.H
autoPtr<incompressible::LESModel> sgsModel
        incompressible::LESModel::New(U, phi, fluid)
to
autoPtr<incompressible::turbulenceModel> turbulence
        incompressible::turbulenceModel::New(U, phi, fluid)
3. In the file UEqns.H
volScalarField nuEff(sgsModel->nut() + iter().nu());
to
volScalarField nuEff(turbulence->nut() + iter().nu());
4. In the file Make/options added the following lines:
-I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
-lincompressibleTurbulenceModel \
Is this all that should be changed in the solver? The solver compiles fine after making these changes in OF 2.3.x. In OF 2.1.1, however, I get a lot of errors.
anuragm is offline   Reply With Quote
Possible turbulence modelling bug in SRF solvers otm OpenFOAM Running, Solving & CFD 3 May 29, 2012 04:03
RAS Turbulence Models - Convective Term john_w OpenFOAM 3 May 29, 2010 21:31
k-ep turbulence modelling allan thomson Main CFD Forum 5 February 20, 2000 20:39
Question about Low Re turbulence modelling. ghlee Main CFD Forum 1 May 28, 1999 19:29
Multigrid Method in Turbulence Modelling Bipin Lokhande Main CFD Forum 1 November 11, 1998 19:20
