No convergence - SimpleFOAM
Like Tree1Likes
  • 1 Post By Tushar@cfd
Old   November 23, 2014, 00:07
Default No convergence - SimpleFOAM
SinaJ
sina_mech is on a distinguished road
Hi FOAMers! :-)
I'm trying to simulate a flow with 2 inlets and 2 outlets. I can't reach a better convergence! Please see the attached for the residuals.
fvSolution
solvers
    p
        solver          GAMG;
        tolerance       1e-07; // was 1e-6
        relTol          0.05; // was 0.1
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration on;
        agglomerator    faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels     1;
    "(U|k|epsilon|R|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06; // was 1e-5
        relTol          0.1; // was 0.1
SIMPLE
    nNonOrthogonalCorrectors 0;  // was 0 !
   residualControl
        p               1e-5;
        U               1e-5;
        "(k|epsilon|omega)" 1e-5;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.5;
        k               0.7;
        epsilon         0.7;
        R               0.7;
        nuTilda         0.7;
fvSchemes
ddtSchemes
    default         steadyState;
gradSchemes
    default         edgeCellsLeastSquares;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss QUICK;
div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
     div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
sina_mech is offline   Reply With Quote
Old   November 23, 2014, 09:49
Joachim Herb
jherb is on a distinguished road
What are your boundary conditions?
jherb is offline   Reply With Quote
Old   November 23, 2014, 14:01
SinaJ
Two velocity inlets (fixed velocity, zero gradient pressure) . Two averaged pressure outlets (0kpa and 10kpa, zero-gradient velocity). The walls are no-slip (zero velocity, zero gradient pressure).
Old   November 23, 2014, 17:42
Joachim Herb
Does the two different pressure outlets make physically sense? Meaning: Is the pressure drop between the two outlets so high?
Old   November 23, 2014, 18:04
SinaJ
Yes It has a physical meaning. and I could get converged solution with Fluent but I want to get the converged solution with OpenFOAM.
Old   November 27, 2014, 07:01
T. Chourushi
Tushar@cfd is on a distinguished road
Hmmm, I would rather check these conditions first. Try with these and check your convergence...
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
Best Luck!
sina_mech likes this.
Tushar@cfd is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
convergence of QUICK scheme - simpleFoam Luis Batista OpenFOAM Running, Solving & CFD 10 May 11, 2013 17:35
Convergence and steady state using simpleFoam sfigato OpenFOAM Running, Solving & CFD 0 February 8, 2013 04:14
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Definition of convergence criterion in simpleFoam titio OpenFOAM Running, Solving & CFD 1 February 6, 2010 01:34
