Strange behavior of water surface near solid body |
January 14, 2019, 13:57 |
Justine
Rep Power: 7 |
I am experiencing strange initial behavior of my water surface near a solid body at the beginning of my simulation.
The water level starts out flat from setFields, and I took away the waves that I will eventually be including. Even with calm initial conditions, the water level dips near the solid flap (the flap is hinged at the bottom so that it may rotate). My boundary conditions on the flap are movingWallVelocity for U, and similar to a normal wall for all others. I am using rigidBodyMotion solver to generate movement of the flap, and an AMI patch rotates a cylindrical portion of the mesh surrounding the flap. In previous simulations, I used a prescribed motion of the flap (with constant rotational velocity) and did not experience the strange initial water surface behavior. Last edited by JBrake; January 15, 2019 at 14:19. |
January 15, 2019, 08:18 |
Paulo Vatavuk
Rep Power: 17 |
Hi Justine,
See the link below for instructions on how to include an image in a post: Picture doesn't appear Best Regards, Paulo Last edited by vatavuk; January 16, 2019 at 06:33. |
January 15, 2019, 18:07 |
Justine
Rep Power: 7 |
Thanks, I have posted an image. As an update, this water surface issue occurs even when I go back to a prescribed flap motion and set the angular velocity to zero (so indeed there is no flap motion, yet still a disturbance near the flap). I am trying to retrace my steps and determine what is causing this issue. Any help would be greatly appreciated.
January 16, 2019, 05:37 |
Peter Baskovich
Rep Power: 11 |
Why movingWallVelocity? Seems wrong to me.
January 16, 2019, 13:14 |
Justine
Rep Power: 7 |
I used movingWallVelocity based on a tutorial case that had a floating object or something of that nature (it might have been the propeller case). Like everything I try to do with OpenFOAM, I find examples and work from there.
The flap is a moving solid body and needs to rotate about a "hinge" point, which happens to be the origin in my model. |
January 16, 2019, 16:12 |
Justine
Rep Power: 7 |
I have removed the flap entirely and found that the behavior continues. It is likely due to the circular AMI. If I plot velocity, there is definitely something going on around the AMI when it shouldn't be.
January 16, 2019, 17:51 |
checkMesh
Justine
Rep Power: 7 |
Additional information: when I run checkMesh, it "Failed 1 mesh checks" but it doesn't say which check it failed. Does it have to do with "***Number of edges not aligned with or perpendicular to non-empty directions: 24057"? Here is a picture of the circular/cylindrical part of the mesh:
Could it be it simply needs more refinement, or is something else possible going wrong with the AMI? |
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Propulsion of solid body in two phases | Nautiker87 | OpenFOAM Pre-Processing | 0 | September 29, 2017 06:45 |
[DesignModeler] Boolean Subtract of a body and a surface | KrishnaSandeep | ANSYS Meshing & Geometry | 2 | April 1, 2015 15:55 |
Rigid Body State Variables in Solid Immersed Simulation | Hamidreza | CFX | 1 | October 19, 2009 06:14 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
