rhoPimpleFoam error
Old   December 28, 2014, 03:34
Default rhoPimpleFoam error
Narmin
Foam_User5 is on a distinguished road
I am running a a case with low velocities around 40m/s and temperature abt 295K but very turbulent flow. This should be an incompressible case, I get this error message after several runs. I have tried to limit the density but this does not help either. Could anyone please help me with this problem?
Thanks
P { margin-bottom: 0.08in; } rho max/min : 10.6085 0.0339423
DICPCG: Solving for p, Initial residual = 0.0386861, Final residual = 0.000172892, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.000474373, Final residual = 1.9557e-07, No Iterations 2
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 6.09946e-11, global = -9.04211e-12, cumulative = 2.51342e-06
PIMPLE: iteration 3
smoothSolver: Solving for Ux, Initial residual = 6.16524e-05, Final residual = 2.7737e-07, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 7.15617e-05, Final residual = 5.43956e-07, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.00023699, Final residual = 6.39866e-07, No Iterations 1
smoothSolver: Solving for h, Initial residual = 0.000177241, Final residual = 2.03319e-07, No Iterations 1
#0 Foam::error: printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::hePsiThermo<FoamsiThermo, FoamureMixture<Foam::sutherlandTransport<Foam::s pecies::thermo<Foam::hConstThermo<FoamerfectGas< Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4 Foam::hePsiThermo<FoamsiThermo, FoamureMixture<Foam::sutherlandTransport<Foam::s pecies::thermo<Foam::hConstThermo<FoamerfectGas< Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/rhoPimpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
Foam_User5 is offline   Reply With Quote
Old   December 31, 2014, 00:44
a
minaret is on a distinguished road
I guess your initial conditions make some problems.
If rhoSimplecFoam runs successfully, you can run it at first and then set the response as the initial condition for rhoPimpleFoam.
(I have done it before)
minaret is offline   Reply With Quote
Old   December 31, 2014, 13:59
a
but it depends on the case. maybe this method is not good for all cases.
now my case runs with my own boundary and initial conditions. without using rhosimplecfoam.
if only openfoam had a good help
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
