conservative or non conservative, Is there a big difference? |
January 4, 2015, 10:37 |
#1 | |
Dongyue Li
Hi guys,
Im using twoPhaseEulerFoam to simulate. we can see that in the latest version of OpenFOAM, this two-fluid model is rewritten into conservative form. before this, its non-conservative form. Right now I know by doing some mathematical rearranging, this two form equations can be the same. for example, see this formula: by adding the term in the middle into non conservative form equation, we can get the conservative form equation. So that means conservative and non-conservative equations can be converted. But Im confused why sometimes we use non-conservative or conservative form to solve. Besides, we should expect non-conservative and conservative's result should be the same rite? I quote this from Henry: Also the fact that 2.3.x is conservative and 2.2.x isn't will affect the results. can anybody explain this to me? because from formula, there two form's equation are the same one. Also, I see Alberto is working on this solver to make it conservative, see this: Quote:
Waiting for any kind of discussion. Thanks. |
April 10, 2015, 04:19 |
Dongyue Li
I tried to do a comparison with FLUENT, Im sure 22x's result is better(non-conservative equations)
This happens on stirred tank using MRF. |
big difference between clockTime and executionTime | LM4112 | OpenFOAM Running, Solving & CFD | 21 | February 15, 2019 03:05 |
Big Difference Between serial run and parallel run case | alundilong | OpenFOAM Running, Solving & CFD | 3 | December 5, 2014 08:27 |
Big difference in temps between real and computed | evidence | Main CFD Forum | 10 | January 26, 2014 06:18 |
XY plots big difference node and face values (thermal boundary layer) | TfG | FLUENT | 0 | May 14, 2009 09:02 |
Conservative finite difference scheme? | Linfeng BI | Main CFD Forum | 1 | October 10, 2002 12:17 |
