January 15, 2015, 07:54 |
Continuing a run
Jeremy Dudley
Looking at previous posts it looked as if I could a simulation by setting startFromn to latestTime.
However, when I did this I get --> FOAM FATAL ERROR: gradientInternalCoeffs cannot be called for a calculatedFvPatchField on patch outlet of field Alpha in file "d:/blueCFD-SingleCore-2.1/OpenFOAM-2.1/tutorials/multiphase/settlingFoam/ras/circular - fixed flow/360/Alpha" You are probably trying to solve for a field with a default boundary condition. From function calculatedFvPatchField<Type>::gradientInternalCoef fs() const in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 196. FOAM exiting In /0/Alpha I specified boundary conditions; in /360/Alpha these have been replaced by numerical values. I did try replacing the contents of boundary{} with the /0/ values, but then I got a message that the token had already been read. Any suggestions on how to proceed? |
January 15, 2015, 09:00 |
Jeremy Dudley
Alpha boundaries file for /360/
boundaryField { inlet { type fixedValue; //calculated; - replacing calculated with fixedValue resolved the error message for this boundary. value uniform 0.00277233; } outlet { type calculated; value nonuniform List<scalar> 3(4.77374e-108 4.65583e-108 4.20304e-108); } bottom { type calculated; value nonuniform List<scalar> 297 ( ) ; } sludge { type calculated; value nonuniform List<scalar> 3(0.00225868 0.00226791 0.00234235); //inletValue $internalField; } endWall { type calculated; value nonuniform List<scalar> 122 ( ) ; } nearWall { type calculated; value nonuniform List<scalar> 54 ( ) ; } surface { type calculated; value nonuniform List<scalar> 295 ( ) ; } otherSurface { type wedge; } } |
Jeremy Dudley
And at /0/
boundaryField { inlet { type fixedValue; value uniform 0.0029; // $internalField; } outlet { type inletOutlet; inletValue $internalField; } sludge { type inletOutlet; inletValue $internalField; } bottom { type zeroGradient; } endWall { type zeroGradient; } nearWall { type zeroGradient; } surface { type zeroGradient; } otherSurface { //type empty; type wedge; } } |
fatal overflow error in the FINMES subroutine for CHT run | prashant79_ss | CFX | 5 | September 27, 2014 04:54 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 06:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
