Continuity error cannot be removed by adjusting the outflow. Please check the velocit |
January 20, 2015, 03:17 |
Warning
Rep Power: 11 |
Hey guys
I am very new to openfoam, when i am using icofoam solver i have been facing this continuity error ,i am having an inflow in horizontal and outflow in vertical. i tried my ways to get over it , i am not able to can any body help me on this. Error: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 376.432 Specified mass inflow : 20 Specified mass outflow : 7220 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&) in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. FOAM exiting P-file dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } walls { type zeroGradient; } } U-file dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (10 0 0); } outlet { type fixedValue; value uniform (0 0 20); } walls { type fixedValue; value uniform (0 0 0); } } |
January 20, 2015, 03:36 |
It looks like area of the outlet is around 180 time greater than area of the inlet. Can you post screenshot of your mesh? |
January 20, 2015, 03:41 |
Warning
Rep Power: 11 |
Yeah, you are true
I just figured it out, i adjusted my boundary conditions and it worked fine thanks for your reply |
August 13, 2016, 07:50 |
alex
Rep Power: 10 |
hi when i run simulation i am getting this error
PHP Code:
August 13, 2016, 08:56 |
Tobias Holzmann
Rep Power: 51 |
This error tells you that it is not possible to adjust your fluxes. This happens if you define your problem weakly. So check your BC and make sure that you have physical BC.
E.g. (just one of a lot of examples)
Keep foaming, Tobias Holzmann |
August 16, 2016, 02:42 |
alex
Rep Power: 10 |
now i have increased my domain size, and i will use the boundary condition given in the propeller tutorial case.
August 16, 2016, 03:15 |
alex
Rep Power: 10 |
I am getting this error
PHP Code:
August 17, 2016, 01:12 |
alex
Rep Power: 10 |
when i dont supply velocity at inlet my simulation is running
continuity error, openfoam 2.1 |
Continuity error cannot be removed by adjusting the outflow | fontania | OpenFOAM Running, Solving & CFD | 1 | October 9, 2012 10:36 |
simpleFoam airfoil2d Continuity error cannot be removed | junkie71189 | OpenFOAM Running, Solving & CFD | 3 | August 9, 2012 13:58 |
PISO nCorrectors and fatal error | jdkummer | OpenFOAM Running, Solving & CFD | 10 | May 30, 2011 16:55 |
MRFInterFoam: Trouble with direction of gravity / Continuity error cannot be removed | bengt | OpenFOAM Running, Solving & CFD | 2 | May 28, 2010 14:45 |
sloshingTank2D3DoF: "Continuity error cannot be removed by adjusting the outflow." | juergenstarck | OpenFOAM Running, Solving & CFD | 3 | May 17, 2009 04:01 |
