January 30, 2015, 11:07 |
"constant power" inlet?
Rep Power: 11 |
Another newbie hits the pavement: Hello cfd-community
I searched the forum (and outside) but couldn't get a thourough answer: I'm working on an aerodynamic structure that is driven by a fan and produces lift (very vague, but i wouln't like to go into further details about it). Now I'm hoping to optimize this a bit through cfd. Therefore I want to compare the lifting force of several slightly modified versions against each other. To make the lift-values comparable, i need to ensure that the flow through my models is driven by an equal amount of power - like i did in my real-world experiments by controlling the input power to the fan. In my first attempt I simply used a constant-velocity inlet, but looking at the inlet pressure values in paraview revealed that there is a huge spread in average inlet pressure amongst the models. At constant velocity this would mean different power-levels for a (hypothetical) fan driving the flow. My first (real newbie) question: Is it ok to look at pressure values directly at an inlet-patch to calculate power, or should this be done a bit downstream on internal cells? I already realized that the TotalPressure BC would be more in my favour, but what I really need is some kind of "constant pumping power" inlet. So here's my second question: Is there an "open-foam-way" to achieve this? I don't ask you to solve this problem for me, just a hint if I'm simply overseeing something. I had a look at the various derived BCs in the code - none of them seemed to fit directly. Maybe the fan-patch could be used for it with an apropriate function for the pressure-drop. |
March 29, 2015, 10:38 |
Rep Power: 11 |
As it turned out, I already gave the answer myself, just in case somebody stumbles across teh same problem:
The solution for me was to use the pressureFan bc for p on the inlet while using pressureInletVelocity for U. To achieve what i called 'constant-power-inlet' I wrote a simple script to calculate a fan-curve for a given input-power and inlet-area using the following formula: input_power = fan_pressure_drop_total * rate_of_volume where: fan_pressure_drop_total = fan_pressure_drop_static + fan_pressure_drop_dynamic (fan_pressure_drop_dynamic = 0.5 * density * square_of(U)) In this nomenclature the fan-curve would be: fan_pressure_drop_static = f (rate_of_volume) leading to: input_power = ( f (rate_of_volume) + fan_pressure_drop_dynamic ) * rate_of_volume which finally can be resolved for: f (rate_of_volume) = (input_power / rate_of_flow) - 0.5 * density * square_of(rate_of_flow / A) (with A beeing inlet-area) As p in icoFoam is not simply pressure but (pressure / density) the pressure-values from that formula (or the fomula itself) would have to be divided by density. |
fan bc, inlet bc |
setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 08:03 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
velocity inlet and ideal gas simultaneously-what's wrong? | preetam69 | FLUENT | 0 | September 28, 2013 04:51 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
