forced convection heat transfer in openfoam
Old   February 1, 2015, 06:05
Default forced convection heat transfer in openfoam
Sandeep Rapol
sandeeprapol is on a distinguished road
Hello friends....
I'm new in OpenFoam and would like to model a system which is known as ECAPS (Engine Combustion Air Preparation System). It is a C-shape duct in which there are two heat exchangers (Chiller and Heater) which are placed in it.
I want to solve this problem in OpenFOAM and the flow at the inlet is turbulent (Re = 2.5 * 10^5) and unsteady state heat transfer (solid fins and fluid region). The heat exchanger which consists of a few horizontal pipes attached to a vertical plate with fluid flowing in gaps between plates.
At inlet the different inputs like Velocity, Pressure and weather conditions (temperature and humidity) are provided and find the output of the system. Depending on this the heat exchangers are handled on or off alternatively.
I want to know which solver will be suitable for my case setup ?
Thank you!
sandeeprapol is offline   Reply With Quote
Porous Domain Natural Convection Heat Transfer EvanOscarSmith CFX 1 July 28, 2014 08:36
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 03:27
