zahra rashidi
Rep Power: 11 ![]() |
hi to every body,
i am trying to simulate a vortex tube,using rhoSimple foam to have a steadystate solution. i used blockmesh to create the axysimmetry grid .i used first order upwind schemes for div terms and all of problem setting attached here. i start run this case and after around 4000 iteration the tempreture and velocity contures seems good compare of experiment result but the pressure conture changes completely from each 100 iterations that means pressure not converged! i chanded the mesh,the order of schemes and the relaxation factor of p untill0.03!but nothing changed!what should i do?what is your idea? |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
