convergencing problem
Old   March 2, 2015, 09:24
Default convergencing problem
zahra rashidi
zahrarashidi is on a distinguished road
hi to every body,
i am trying to simulate a vortex tube,using rhoSimple foam to have a steadystate solution.
i used blockmesh to create the axysimmetry grid .i used first order upwind schemes for div terms and all of problem setting attached here.
i start run this case and after around 4000 iteration the tempreture and velocity contures seems good compare of experiment result but the pressure conture changes completely from each 100 iterations that means pressure not converged!
i chanded the mesh,the order of schemes and the relaxation factor of p untill0.03!but nothing changed!what should i do?what is your idea?
zahrarashidi is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
