anyone used setFields for igniting a flame (reactingFoam) ?
Old   March 3, 2015, 21:22
Default anyone used setFields for igniting a flame (reactingFoam) ?
Daniel
Dan1788 is on a distinguished road
Hello all,
I am using reactingFOAM for an LES of premixed flame calculation (methane+air premixture) in OF-2.2.x. To ignite the flame, I set a patch of temperature using setFields like this: (I also set mass fraction of CO2 and H2O in this patch)
When I ran the simulation for a couple of time steps, the temperature field became something like this:
Ultimately however, the temperature in some cells went past 3500 K and the code produced NAN
Could someone tell me how to use the setFields utility correctly for a premixed flame ? Which zone should we patch with a temperature field ? Please help
Dan1788 is offline   Reply With Quote
Old   March 5, 2015, 21:06
Daniel
Anyone who might know how to use setFields for flame ignition ??
Old   March 6, 2015, 07:23
hajott is on a distinguished road
reactingFoam crashes with NaNs when the temperature exceeds the maximum temperature which thermodynamic data are available for.
I don't think the problem is your setFieldsDict, but you would have to attach your case directory if you want feedback on your approach.
hajott is offline   Reply With Quote
Old   March 9, 2015, 12:57
Daniel
Hi Hajott,
Thanks for your reply. Basically a schematic of my flow domain looks like this:
My fvSchemes are the following:
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(pd)        Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss limitedLinearV 1;
    div(phi,h)      Gauss limitedLinear 1;
    div(phi,Yi_h)   Gauss limitedLinear 1;
    div(phi,K)      Gauss limitedLinear 1;
    div(phid,pd)    Gauss limitedLinear 1;
    div(phi,epsilon) Gauss limitedLinear 1;
    div(phi,k)      Gauss limitedLinear 1;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    //default         Gauss linear orthogonal;
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
   //default         orthogonal;
   default          corrected;
fluxRequired
    default         no;
    pd;
The fvSolution file is as follows:
solvers
    rho
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.1;
    rhoFinal
        $rho;
        tolerance        1e-06;
        relTol           0;
    pd
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.1;
	    maxIter		     100;
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      1;
	    nFinestSweeps    2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 50;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    pdFinal
        solver           GAMG;
        tolerance        1e-6;
        relTol           1.0e-2;
	    maxIter		     100;
        nPreSweeps       0;
        nPostSweeps      1;
	    nFinestSweeps    2;
        mergeLevels      1;
    "(U|h|k|epsilon)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0.1;
    "(U|h|k|epsilon)Final"
        solver          PBiCG;
        tolerance       1e-06;
        relTol          0;
    Yi
        $hFinal;
PIMPLE
    momentumPredictor   yes;
    nOuterCorrectors    2;
    nCorrectors         3;
    nNonOrthogonalCorrectors 0;
For the boundary conditions, I use fixedValue for atmospheric pressure at outlet, inletOutlet for velocity and scalars at outlet, and slip wall boundary at the sides of my domain.
I have also attached my case in the zip file. Any comments or suggestions would be really appreciated
how to achieve ignition of premixed flame using ReactingFoam Dan1788 OpenFOAM Running, Solving & CFD 25 June 12, 2022 04:52
how to use setFields for flame ignition?? Dan1788 OpenFOAM Running, Solving & CFD 5 September 25, 2014 20:26
calculate flame speed using reactingFoam IColin OpenFOAM Running, Solving & CFD 0 February 4, 2014 15:14
Flame gets flushed away in reactingFoam megacrout OpenFOAM 7 November 7, 2011 05:33
Crosswind flame with reactingFoam torvic OpenFOAM Running, Solving & CFD 1 September 10, 2007 17:48
