Solver Suggestions: Incompressible, high pressure, 3 phases, steady state
Like Tree2Likes
  • 1 Post By olivierG
  • 1 Post By hajott
Old   March 6, 2015, 06:47
Default Solver Suggestions: Incompressible, high pressure, 3 phases, steady state
Sam_CFD is on a distinguished road
Deat All,
I am new to OpenFOAM. Could you please help me to select a proper solver for the following problem.
My problem is
1. Incompressible
2. High pressure ( 200 Bar at inlet and outlet 1 bar)
3. 3 phases involved (Beginning only Air and Liquid later Liquid-vapour formation)
4. Steady State
I have attached a pic which is similar to my model. That pic is only at initial condition.
As iterations go on, there exist liquid-vapour phase as liquid gets evaporated. Sometime cavitation also comes into picture.
Please suggest me the solver which suits my condition.
Regards,
Sam
Sam_CFD is offline   Reply With Quote
Old   March 6, 2015, 07:15
hajott is on a distinguished road
Is the vapour and the air immiscible? Otherwise you have a 2-phase problem and can use any of the VOF-solvers.
hajott is offline   Reply With Quote
Old   March 6, 2015, 07:23
Default solver name
They are immiscible.
Could you please mention the solver name ?
Old   March 6, 2015, 07:30
Have a look in $FOAM_SOLVERS/multiphase, whether you find a 3-phase solver. As I said, I have only used 2-phase solvers.
What is the chemical composition of the liquid?
Old   March 6, 2015, 10:28
Olivier
olivierG is on a distinguished road
Take a look at "cavitatingFoam", or "interPhaseChangeFoam".
regards,
olivier
Sam_CFD likes this.
olivierG is offline   Reply With Quote
Old   March 8, 2015, 23:38
Liquid is Methanol .
Old   March 9, 2015, 03:28
You will have a liquid methanol phase and a vapor phase consisting of air and methanol. Do you have a reference that suggests why there should be a third phase?
Sam_CFD likes this.
Old   March 9, 2015, 03:32
Yes It is said that after the some liquid get evaporated when it passes through nozzle.
Because of sudden drop in the pressure.
Old   March 9, 2015, 03:36
As you say: the liquid evaporates. Afterwards it is in the vapor phase and mixes with air. Please give your reference, or it doesn't make sense to discuss this.
Old   March 9, 2015, 05:00
I am not able to get the meaning of "Your reference" in your post.
Could you please elaborate ?
Old   March 9, 2015, 05:05
I though you have some publication that explains why you expect three phases. This is what I mean by "reference".
Good luck with your project. I am out of this discussion.
Old   March 9, 2015, 05:40
The reference is CFX-pre file provided to me where the initiallisation is done with 2 phases but another phase called liquid-vapour is also included.
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
modify reactingFoam in order to make it a steady state solver Peoban2 OpenFOAM Programming & Development 9 October 10, 2015 03:18
Steady state incompressible flow Bharat Rangan (Rangan) OpenFOAM Running, Solving & CFD 10 November 22, 2010 15:21
time step and iterations in steady state problem using transient solver jing113cn FLUENT 2 January 15, 2010 03:18
Steady State All Mach Numbers Solver mkraposhin OpenFOAM Running, Solving & CFD 0 March 9, 2009 03:22
