Unrealistic supersonic pockets at pressure inlet
Old   March 7, 2015, 16:52
Default Unrealistic supersonic pockets at pressure inlet
c0sk is on a distinguished road
Hi!
For my undergrad project I am trying to simulate an airfoil in a wind tunnel using the sonicFoam solver. I run the case on a big domain with fixed velocity inlet and worked fine. When moved to pressure inlet I am struggling. As you can see from the picture with the bent duct, there are pockets of insanely high speeds (up to Mach 9). The boundary conditions are fixed value (1.6 bar and 1 bar wave trasmissive) at both the inlet and outlet and the velocity BC are fixedGradient. I am trying to achieve inlet velocity of Ma 0.4 and this should be done by having constant pressure inlet. I have been trying everything and pretty desperate right now.
When testing the pressure conditions with the big domain, i dont get the pockets but the strange flow pattern near the outlet.
What am I getting wrong?!
U
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform (0 0 0);
boundaryField
back
type zeroGradient;
front
type zeroGradient;
top
type fixedValue;
value uniform ( 0 0 0);
right
type zeroGradient;
bottom
type fixedValue;
left
type pressureInletVelocity;
value uniform (0 0 0);
foil
type fixedValue;
P
dimensions [ 1 -1 -2 0 0 0 0 ];
internalField uniform 100000.0;
boundaryField
back
type zeroGradient;
front
type zeroGradient;
top
type zeroGradient;
right
type waveTransmissive;
field p;
phi phi;
rho rho;
psi thermosi;
gamma 1.3;
fieldInf 100000;
lInf 1;
value uniform 100000;;
bottom
type zeroGradient;
left
type fixedValue;
value uniform 160000.0;
foil
type zeroGradient;
Thank you so much
c0sk is offline   Reply With Quote
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 01:37
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
B.C. for Supersonic inlet ? jakjak CFX 1 December 3, 2007 15:27
Pressure jump on supersonic velocity inlet Viktor FLUENT 0 August 9, 2007 00:23
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
