March 7, 2015, 17:18 |
interFoam Stability Issues
Darren
Rep Power: 13 |
I am trying to simulate an outlet chamber using interFoam but no matter what combination of boundary conditions I choose - I seem to run into a stability issue after a varied amount of time into the simulation.
InterFoam decreases the time step continually until a floating point error occurs. I have based the case set up on the waterChannel tutorial file - but i have tried numerous alternative configurations of boundary conditions and not yet found anything that actually works. The mesh was constructed using Salome and represents a fairly simple situation where two pumped high velocity inlets enter a small outlet chamber, the chamber is equipped with two simple gravity outlet pipes. I have included a drop box link to the case files below. https://www.dropbox.com/sh/m06gbu64j...aBwSqGcfa?dl=0 If anyone out there can shed any light on this - it would make my year. Thanks |
March 8, 2015, 04:15 |
Rep Power: 11 |
1) You mesh have some non-ortho faces, but you have no correctors in your fvSolution: "nNonOrthogonalCorrectors 0;"
2) It seems that you initial time step is too big, try to reduce it 3) Always check your mesh with checkMesh. In the output have to be no-errors or warnings. |
March 11, 2015, 16:46 |
Stability Issues
Darren
Rep Power: 13 |
I have tried increasing the number of orthoCorrectors and this helps the simulation limp on a little further.
But I still get the same problem little later in the process. I have tried adusting the max Courant number and the tolerance in the Fvsolution file - but none of this actually seems enough to push this over the edge and develop a stable solution. Anyone got any other ideas ? |
March 12, 2015, 02:04 |
Rep Power: 11 |
Try to simulate with "adjustTimeStep no" and small value of deltaT.
Adjusting of the time step in some situation may not work correctly. |
boundary conditions, interfoam, stability |
p_rgh issues with interFoam (2.0.x) | gfilip | OpenFOAM Running, Solving & CFD | 7 | January 10, 2019 06:47 |
having some issues in Wake Stability using UVLM for propellers | jackgeo | Main CFD Forum | 1 | November 26, 2014 05:05 |
Multigrid Stability Issues | ThomasHermann | SU2 | 1 | November 5, 2014 16:18 |
Convergence Stability Issues | ts_swati | Fluent Multiphase | 0 | July 7, 2014 21:11 |
Numerical stability issues | poornima | Main CFD Forum | 2 | June 7, 2006 11:04 |
