Problem with dynamic mesh and mesh decomposition
Old   March 9, 2015, 06:08
Default Problem with dynamic mesh and mesh decomposition
Sebastian
Zyryx is on a distinguished road
I am testing dynamic mesh with layer addition/removal, so I crated a simple 2D case with moving car through a domain. Domain is composed of 2 cellzones (see the picture) and mesh modifier removes/adds cells only in the blue region. When I run the case in serial everything seems ok, but when I run it in parallel, solution crashes with the following error:
Face 710 is active but its owner has been deleted. This is usually due to deleting cells without modifying exposed faces to be boundary faces.
After short investigation it turned out, that solution crashes when the extrusion faces in front of the car reach the processor boundary. You can see the domain decomposition in the atteched picture. I know I can avoid this error by leaving lower cellzone in one piece, but is there any other way?
Zyryx is offline   Reply With Quote
dynamic mesh for multi-region problem alundilong OpenFOAM Programming & Development 6 June 5, 2023 19:13
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
problem on dynamic mesh zone erkan FLUENT 2 January 8, 2009 16:01
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
