Patch-averaging in OpenFOAM
Old   March 10, 2015, 08:42
Default Patch-averaging in OpenFOAM
d.lagattolla is on a distinguished road
Hi everybody! My problem is the following..
I need to calculate the average pressure and velocity on a patch..i would like to know if there is a function which gives output files like the ones given by the "probe function", so for a certain number of timeSteps.
I have read posts about the patchAverage function, but as far as I have understood it can only be used as a postProcessing tool, so after the simulation has finished. And it only gives results every writeInterval, so every time openfoam saves during the simulation.
Is there a way to use this utility in run time to save every timeStep or anyway to set the number of timeSteps? Or another utility that does what i need?
Thanks in advance!
d.lagattolla is offline   Reply With Quote
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
